Fuel pump issue ? is it fubared ?
Started by Alnico Blue, 28 February 2021, 09:53:42
Alnico Blue
Hi All . .  .not been on here much latley  . . .long story  . . . but have an issue . .
2001 2.6 Estate . . .     3  days ago used the car for a 50 mile round trip , all running perfectly.
Then 2 days ago  went to use car and although it fires a revs to about 1000rpm it then cuts out after about 1 sec . Tried to re start and same thing happens several times.
  Seem to remember advice on here was to give the underside of the tank a thump . . .  did so  . . and car started an ran perfectly  :-\    There are no warning lights on .
   Same happened yesterday  . . .had to thump the tank  after it had been left overnight.
  Assume this is a fuel pump issue  . . .is replacememnt the answer or can they be serviced . ?   TIA   AL
British made Celestion Alnico Blue = best sounding guitar speaker ever, sadly now made in China
dave the builder
Serviceable in that you can replace just the pump rather than the whole swirl pot assembly
pump clicky 9196213 is showing for caravan (estate) and saloon
https://vauxhall.7zap.com/en/car/v94/g/0/23-1/#4
dave the builder
symptoms point to the pump
the fuel pump uses fuel to lubricate itself ,so running out of fuel thus running the pump dry can kill it  :(
Carltons suffered badly with poor electrical connection to the pump plug
fuel pump relay on Omega is a very simple relay, easy to get at and bypass for test purposes /
also worth checking you don't have any immobilizer stored codes
Alnico Blue
Quote from: dave the builder on 28 February 2021, 11:04:01
Is replacing just the pump fairly straight forward . . . as in get access to whole pump assembly through estate load area floor, take pump out of "swirl pot"  , replace and reassemble / :-\
Thanks for your reply. :y
Alnico Blue
Quote from: dave the builder on 28 February 2021, 11:12:09
No codes showing Dave.  The fact that thumping the tank lets the car start and run fine  must point to it being the pump. . . do you agree.    My diagnosis at first was  . . crank sensor  or fuel pump .
dave the builder
Or if money is tight a LUCAS pump £21.16
£2 extra for first class post  ;)
Quote from: Alnico Blue on 28 February 2021, 11:40:00
pretty simple ,does require taking the old pump out of the swirl pot assembly and putting the new one in ,but that's not hard , i'll see if i can find a youtube vid of a similar procedure ,doubt there's an omega video
pump lives in this type of "swirl pot" assembly (example image)
Opti did it, on a corsa, bound to be a piece of piss.
Diesel till I die
Alnico Blue
Ok . . .yer should be able to manage that  . . .    Thanks gents :y
dave the builder
How's your German clicky   ;D
that's a saloon ,removing the pump from tank but the estate will be similar
struggling to find a take pump out of swirl pot video  :(
The internal hose clamps are probably single use, but that's easily sorted.
The swirl pot clips together, and is old plastic so a bit of care is necessary.
The actual pump is a pretty standard part and shouldn't cost much.
dave the builder
Good advice from Nick :)
I forgot about fuel line clamps ,it's something I've always got "in stock"  :-[
Quote from: dave the builder on 28 February 2021, 12:38:32
Yes so do I, along with ones suitable for radiator and heater hoses.
Alnico Blue
As I read it. . There are saloon and estate types  . The £21 Lucas one is listed as not suitable for estate.  Same company do estate version of Lucas one for £29  can any confirm there are 2 types please?
Quote from: Alnico Blue on 28 February 2021, 15:12:56
For the £8 difference I'd buy the one they list for estates without a second thought.
dave the builder
Bosch one does state saloon and caravan
It's very odd ,
OPEL Omega B Caravan (V94) (Year of Construction 04.1994 - 07.2003, 144 - 218 PS, Petrol)
2.2 16V (F35, M35, P35), Year of Construction 09.1999 - 07.2003, 2198 ccm, 144 PS
2.6 V6 (F35, M35, P35), Year of Construction 09.2000 - 07.2003, 2597 ccm, 180 PS
3.0 V6 (F35, M35, P35), Year of Construction 04.1994 - 02.2001, 2962 ccm, 211 PS
3.2 V6 (F35, M35, P35), Year of Construction 02.2001 - 07.2003, 3175 ccm, 218 PS
and
OPEL Omega B Saloon (V94) (Year of Construction 04.1994 - 07.2003, 144 - 218 PS, Petrol)
2.2 16V (F69, M69, P69), Year of Construction 09.1999 - 07.2003, 2198 ccm, 144 PS
2.6 V6 (F69, M69, P69), Year of Construction 09.2000 - 07.2003, 2597 ccm, 180 PS
3.0 V6 (F69, M69, P69), Year of Construction 04.1994 - 02.2001, 2962 ccm, 211 PS
3.2 V6 (F69, M69, P69), Year of Construction 02.2001 - 07.2003, 3175 ccm, 218 PS
but
VAUXHALL Omega (B) Saloon (V94) (Year of Construction 04.1994 - 07.2003, 180 - 218 PS, Petrol)
2.6 V6, Year of Construction 08.2000 - 07.2003, 2597 ccm, 180 PS
3.0 V6, Year of Construction 04.1994 - 07.2000, 2962 ccm, 211 PS
3.2 V6, Year of Construction 02.2001 - 07.2003, 3175 ccm, 218 PS
