Author Topic: Fuel pump issue ? is it fubared ?  (Read 23312 times)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Fuel pump issue ? is it fubared ?
« Reply #16 on: 28 February 2021, 19:19:11 »
Swapping the pump out takes less than an hour.
Relay is a red herring if thumping the tank makes it run.
Carpet out, six screws on the stainless plate.
Unscrew the retaining ring with a blunt screw driver/block of wood. It's bastid tight, but not secured by magic.
Unclip the fuel lines and tuck to one side.
Pry the lid off.
Three clips hold the pump carrier in the swirl pot.
Either replace or swap out the pump alone.
Bish, bash bosh :y
The actual pump is common to both saloon and estate. Buy the most convenient and swap it into your original assembly ;)
Stu.C
  • Lancashire
    • 2.0 Capri / 3.0 Elite-ish
    • Visit the blog...
« Reply #17 on: 28 February 2021, 20:38:53 »
When you get to it, you'll find there's three tabs around the edge of the swirl pot holding it into the base in the tank. Press them in at the same time and the pot lifts out. You then work round the top and squeeze together each of the serrated tabs arrowed below, which releases the pump retainer piece in the middle. My new Chinesium pump came with a new pickup filter too - not bad for 25 quid next day from Amazon...
Nothing better to do ? Visit the blog at cuyahoga.co.uk
« Reply #18 on: 01 March 2021, 10:07:30 »
See how long it lasts at that price :-X
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19 on: 01 March 2021, 11:25:25 »
The Bosch one is £34.32 if you select first class post
« Reply #20 on: 01 March 2021, 12:32:28 »
Indeed. Worth the extra £10
Alnico Blue
  • Costa del 'Saffend
    • 2001 2.6 CDX estate
« Reply #21 on: 01 March 2021, 12:41:37 »
OK Thanks  gents all info and advice taken on board. Excellent info and pics as usual from you OOFers.Will go for the Bosch one  :y :y . . . . . When I'm up to speed to be able to tackle it  :'( :'(
« Last Edit: 01 March 2021, 12:51:14 by Alnico Blue »
British made Celestion Alnico Blue = best sounding guitar speaker ever, sadly now made in China
« Reply #22 on: 01 March 2021, 14:54:06 »
The fumes will clear the crevices out :y
Alnico Blue
« Reply #23 on: 05 March 2021, 13:41:22 »
Ok  have had Bosch pump delivered. Got assistance to attempt to do it .   But pump is different part No. from my original .
The box has a seal on it , so reluctant to open , but my original pump is longer that the box the new one comes in  . . .
not good :-\
Original part no. is 0 580 453 985    new one supplied is  0 580 453 489   could this be an updated compatible part ?
Waiting for supplier to e mail back as reluctant to break seal and then they wont take it back  . . .but thought I would ask on here while waiting.        TIA Al   :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #24 on: 05 March 2021, 14:28:45 »
Was the one you bought listed for an estate? If so, open the box, take a photo of both pumps side by side and contact the supplier.
Perhaps the difference in length is due to the shallow, wide, underfloor estate tank compared to the deep, upright saloon one?
Enceladus
  • London
« Reply #25 on: 05 March 2021, 14:37:41 »
So far as I can see, GM part #9196213 is Bosch 0 580 453 489. Same as dave the builder linked to below. And it's a fuel pump for an Omega B.
However it doesn't seem to be the same as the one fitted to your car.
Bosch 0 580 453 985 appears to be GM #9119098 which is NLS. It's superseded by GM #93181359 also used on Astra G and Vectra B.
I think you need to compare your pump with a good picture of a GM #93181359.
cross referencing on https://www.autodoc.co.uk/bosch/1156426
the Bosch one also states saloon and estate in the ebay listing
https://www.ebay.co.uk/itm/Fuel-Pump-fits-OPEL-OMEGA-B-2-6-In-tank-00-to-03-Y26SE-Bosch-815038-9196213-New/333841712077?fits=Model%3AOmega&hash=item4dba8443cd:g:cS0AAOSwcMlf7F9f
Alnico Blue
« Reply #26 on: 05 March 2021, 15:02:57 »
Supplier says if box is opened they will not exchange or refund. Yet another nightmare of online shopping.
  • Chatham, Kent
« Reply #27 on: 05 March 2021, 15:19:46 »
Good point.
But if your pump is longer than the box, the pump inside it can't be right.
Alnico Blue
« Reply #28 on: 05 March 2021, 15:47:03 »
the part no. of the original pump  0 580 453 985    comes up as being for a senator on my googaling.  So do I try and find one of those and just order it ?
also going to check the numbers on the Lucas one that Dave found  and posted up   :-\
update :  the Lucas one is the same number as the newly supplied one   ends in 489   :'( :'( :'(
So now gonna search for a pump with this number  0 580 453 985
« Last Edit: 05 March 2021, 15:54:32 by Alnico Blue »
Enceladus
  • London
« Reply #29 on: 05 March 2021, 16:10:56 »
Might help if you post up a good picture of your pump.
Your original part is NLS and superseded, hence I'm wondering if the later part can still be used with the earlier swirl-pot?
Might this be the pump you need, Delphi version.
Pages: 1 [2] 3 4  All   Go Up
