Author Topic: Must I take them to the tip?  (Read 5231 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« on: 10 March 2021, 14:23:08 »
Make me an offer for parts or the lot.
93182287   DF4247 Lucas Vented discs               Pr New £25
90511451   Cam cover seals, AM                      2   BNIP   £15
24410986   Servotronic power steering relay          1   Used   £10
25313359   Fuel Filter AM                          1   BNIB £10
90324059   Insulator                              2   BNIP   £2
90251877   Rear suspension levelling pipe 730mm long      1   BNIP   £12
90473521                ”         275mm long    2 BNIP £12
93185493   Lamda sensor Length 570mm + spanner      1   BNIP   £35
90389377   02749 FEBI Ignition switch AM              1   BNIB £2
90565803   MFL LH headlamp Xenon                  1   Used   £10
90565819   MFL LH Foglamp                      1   Used   £5
90457820   MFL RH foglamp                       1 Used £5
9195572   Side Indicator lamps, late type clear glass     Pr   Used   £3
90529188   Timing Belt Roller washer                  4   BNIP   £4
90487795   2.5TD sump gasket                      1   BNIP   £5
90460437   Front light trim LH                      1   Used   £3
90460438   Front light trim RH                      1   Used   £3
90566026  Black RH Insert corner trim with tweeter £2
      Omega Handbrake gaiter green AM          1 New   £5
     Bose Disc cassette                          1 Used £5
   Assorted new nuts, bolts and fixings for Omega         POA
Shackeng
  • Ramsbury
Re: Must I take them to the tip?
« Reply #1 on: 10 March 2021, 14:26:24 »
Apologies, Timing belt rolled washers have gone.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 10 March 2021, 14:59:58 »
I would want £50 posted for the lot, the discs are the killer on carriage, unless you have a good friend who can use a company account.
Hoof'land storeman.
Shackeng
  • Ramsbury
« Reply #3 on: 10 March 2021, 16:37:32 »
Yes its a shame, since lockdown the OOF delivery service has ceased operating. :(
« Reply #4 on: 10 March 2021, 18:30:21 »
A couple more months to wait...  ;)
