Spraying costs
Started by Terbs, 09 April 2021, 13:38:40
YZ250
Quote from: Doctor Gollum on 10 April 2021, 13:43:42
Screens out, side channel trims off (handful of screws),
Rear quarter trims off (unclip) and that's it.
Sunroof meeans headlining out and sunroof cassette out (all straightforward, just more effort).
Gotta love this forum .....All very straightforward..... Just pop the screens out ..... like you are whipping out a pair of contact lenses.  ;D  :y
Quote from: YZ250 on 10 April 2021, 14:29:59
Turning a £300 tidy-up job for anyone practiced with a spraygun into a specialist job that will inevitably require a new screen and its trims, all of which will add another £1000.
As for the sunroof, why remove it when you can just open it and mask inside the vertical edges? ???
I do prefer to remove rather than mask, but reality means that certain parts stay in place and bonded in screens are always at the top of that list.
When I did this,
removing and replacing the side glass took less time than masking around it for a good result would have done. Same applies to the back bumper; removing it meant undoing four M6 bolts which is easier and quicker than masking it. And meant I could flick some body colour over the repairs to the rear valence.
The whole car is covered in one sheet of body mask, with the quarter panel and sill cut out and edges taped down, which took about five minutes. The B-pillar is masked - by covering with tape and cutting the raised edges with a scalpel - because I didn't want to replace the stick on black trim. What I should have done with this job, because it included painting the replacement front wing, was strip the mirror, door handle and drop glass trim and paint the door as well.
Quote from: Nick W on 10 April 2021, 15:02:29.....
Same applies to the back bumper; removing it meant undoing four M6 bolts which is easier and quicker than masking it.  ...
I wish I could have said the same today for the front bumper of SWMBO's C3 ... in theory, there are 4 self tappers across the front on the 'slam panel' and a couple of M6s under the front valance. The ball ache was undoing wheel arch liners to get to the clip behind the headlights that clip the edges of the bumper to the bottom edge of the wing.
You're right of course ;)
It just really grips my shit when people don't take the time to actually mask stuff properly... I mean, if you cba to tape a straight edge, er, straight, then simply don't bother taping it to begin with. Either take the time to mask it properly, or simply pop the trim off and mask where it's hidden...
Rubbing strips and door capping trims being just two examples of lazy arsed bodgery on cheaper jobs. There's simply no excuse for wavy overspray edges on chrome and rubber trim that would have been quicker to remove than mask badly.
Quote from: Andy B on 10 April 2021, 15:43:20
Still better than failing to mask the panel gap with anything like accuracy... Not to mention the resultant paint flaking etc where they haven't bothered to prep the bits they cba to mask/remove.
Rangie
#20
Quote from: Terbs on 09 April 2021, 14:19:32
Glad you said that......I had it in my own mind it probably would be about £500. Based on that, I shall see if I can get a quote. Had you said around a thousand, I would not bother.
TB...if you read this, have you any experience of sprayers in Brackley. :)
I know good work is now expensive because my mate is having his MGB GT V8 repainted at the moment ,the car is thoroughly stripped at present ( I've seen the pics) he has placed a deposit of  £5,000 for work to commence, he has used the same specialist in  Cambridgeshire ( Malcolm Beer) for all his MGs for many years.
YZ250
Just to clarify my reply, as not everybody understands my humour/sarcasm, I meant that Al made it sound so matter of fact, which it probably is if you've done it a few times. I wasn't implying to do one or the other as a preference and I do fully understand the reasoning of Nicks reply.  :y
YZ250
Quote from: TheBoy on 09 April 2021, 18:30:51
'Fraid not. ....
This surprises me, I thought you were the man for spraying things around Brackley, .............. like gas cylinders, garage doors etc.   ;) ::)
cam.in.head
When my roof was done 5 years ago the front screen rubber was just lifted and the sunroof opened. That was a £500 job but did only last 5 years until the little dots started appearing again.
This time they removed the screen to do a better job as a small line or rust had gone under and into the screen aperture. Again sunroof opened and rear pillar trims removed.
This time it was bare metalled but. Also the bonnet,boot and sides above waistline too so cannot compare price wise.
Quote from: cam.in.head on 11 April 2021, 13:25:32
QED
Quote from: YZ250 on 11 April 2021, 10:47:55
'Fraid not. ....
Thame is within the blast radius, so be mindful what you say Mr YZ :P
Terbs
I haven't got a sunroof.  ;D
Quote from: Terbs on 11 April 2021, 18:58:01
One can be arranged. I have a tin opener.
One less thing to remove then  :D
deviator
Quote from: Doctor Gollum on 11 April 2021, 20:04:09
No, he means, he had one last night but now..... :D
