Duff V6 GM Crank Sensor!
Started by johnnydog, 17 April 2021, 17:52:14
johnnydog
Well, so much for buying a 'genuine Vauxhall crankshaft sensor from a genuine Vauxhall dealer that you have to genuinely walk into...' My 2.6 began being intermittently reluctant to fire recently, although would crank forever. No EML, so I changed the crank sensor with brand new boxed (sealed) genuine GM sensor bought from Vauxhall. After fitting, it cranked and fired virtually straight way. Happy Days, I thought. Turned off, and after putting the tools away, decided to go for a test drive. Same symptoms  >:( - would crank for ever and a day, but not fire. Checked sensor was fitted in the block square, removed it to make sure no contaminants had got onto it, refitted it, but still nothing. Decided to remove a known used Bosch sensor from a 3.2 which was running well before being laid up for spares (rotten front chassis rails) a few years ago. Fitted it, and it has started everytime. After several test runs, all is well, starting first turn everytime.
I realise sometimes parts are faulty, but you wouldn't expect it from a genuine Vauxhall part bought from a genuine Vauxhall dealer that you .......etc etc............you know what I'm saying.
I heard that at some point there was a faulty batch, but this may be fiction?
dave the builder
that's not good  :(
I've had brand new parts not work before ,very frustrating and leaves you questioning your diagnosis
it's good you had a known good working one to try though  :)
is there any chance of refund or replacement on the new but not working item ?
You've misunderstood the reason for buying a genuine GM part by walking into a dealer.
It's not that it's going to be any more reliable than buying the same sensor that's genuine Bosch/Siemens/whatever, but that your chances of getting a genuine one are much higher. Some haggling means the price shouldn't be much different to a branded part.
The return procedure if it does prove to be faulty should be easier.
We have to accept that this is going to be fairly old stock, although that's more likely to affect parts that contain rubber and plastic like gaskets, seals, HBVs and so on.
biggriffin
Metal case or plastic case on the sensor, 3.2 dont like metal case sensor,, that's my own finding,others may say different.
Hoof'land storeman.
johnnydog
It was a GM Bosch sensor with an identical Bosch id no as the old one (and the good used GM Bosch sensor) with a plastic head to the sensor itself where the part number is.
I might try my hand at returning it to the dealership as I have a good relationship with them having bought my VX parts there for at least 17 years, but not holding my breath as I bought it at a very good price a couple of years ago with a box full of other 'service items' when they were clearing their shelves of 'out of date' Omega stock. If they can't change it due to the time lapse, then I'm not unduly worried as they have always given me very good discount, but having said that I'm just miffed it was faulty from a sealed genuine VX box, and even more so that I had to do the job effectively 2 1/2 times!!
johnnydog
Quote from: Nick W on 17 April 2021, 18:25:26
The reasons and benefits of buying a genuine VX part direct from a VX dealer are quite obvious, and apart from virtually guaranteeing the item is a genuine GM part, you would also expect it to work as intended / designed. So, no, I have not misunderstood the recommendations as to the sourcing of a sensor relative to their supposed reliability. I mentioned the points about being a genuine sensor/ dealer / walking into it to reduce the chances of these now 'repetitive' points possibly being raised.
Quote from: johnnydog on 17 April 2021, 21:41:27
I've read your post several times, and still can't decide if you're agreeing, or disagreeing with me as you've just re-phrased everything I wrote.
johnnydog
I'm not agreeing or disagreeing with your comments - I am just stating the facts as they happened to me.
Genuine dealer - genuine part - expectation that it works as intended.
Alternative purchase options were -
EBay / Amazon (of advertised GM / Bosch item)  - possibility of a genuine part  but some suggest could be fakes (although all my past Bosch purchases on Ebay have been genuine parts) with fingers xd's that it works as intended.
EBay/ Amazon purchase of non genuine / aftermarket part - likelihood of early failure a possibility / reality?
So I don't really know why you are picking holes in the facts as I explained them - VX dealer, genuine part, high expectations that that it should work. Unfortunately it didn't. Simple really.
Meanwhile in other news...
It would seem that the issue isn't with the part failing or from whence it came but the opportunity to have a dig a tried and tested advice.
Buy the next one from Faceachebook market place and then spend the next six months going on about how good it is because I didn't suggest it. ;D
Buy ensuring that you buy a genuine one, you minimise the likelihood of a failure. My memory is fading but I suspect that it is the second genuine one, (purchased from a genuine Vauxhall dealer that you genuinely have to walk in to) that has failed since I first joined the forum in 2009. Whereas buying them anywhete else is a crapshoot with 50/50 odds of it lasting a month.
johnnydog
Quote from: Doctor Gollum on 18 April 2021, 00:29:10
You're being bit over sensitive I think.... :)
Had I just stated I had fitted a brand new Vauxhall sensor and it was faulty / didn't work, I am certain that the usual reply about buying any other than a genuine part from a genuine Vauxhall dealer that you genuinely have to walk into' would have been the first point raised.....
Mentioning it from the outset saved it having to be asked - and confirmed that I had adhered to the recommendations.....
I wouldn't even have considered fitting an aftermarket electrical part bought on the Internet, especially the crank sensor.
Your first sentence of your first post suggests different as I am the one who consistently phrased the advice that way.
Anyhoo, the advice stands.
dave the builder
There's a lot more than 2 genuine ,from a dealer omega sensors failed  ::)
because the ones fitted to the cars at the factory where purchased from a dealer and where genuine ,albeit purchased as a package of parts (the Omega)  :D
never had a Carlton crank sensor fail in 20 years of ownership (4 Carltons)
I have had 2 astra H crank sensors with intermittent faults I've replaced
so maybe the newer manufacturing processes are to blame  :-\
Smart arse :P
The loom bakes over time, which in turn corrupts the signal from the sensor. They typically last as long as the suspension bushes...
My plod had a new sensor at 130k which was still on the car when I sold it at well north of 260k having been routed as per the guide.
Quote from: dave the builder on 18 April 2021, 12:37:56....
I never had one fail on my Senators or Carlton or Manta either .... mainly because they had a dizzy & points  ::) ::)
Rangie
Never had to replace any on my two Omegas just lucky I guess.
