Author Topic: Battery Powered Flight.  (Read 3504 times)
« on: 16 May 2021, 20:17:32 »
Bad enough running out of juice in a car, but the same thing happeing a few 1000 feet in the air.  Dont think it's for me.
Cute looking though. ::)
https://newatlas.com/aircraft/eviation-alice-magnix/?fbclid=IwAR1HpV-Pb8w9QWXjdIqulltjsMln9qI2XzeuUTL5kk2KnvzZx6f_4tsHvA8
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Battery Powered Flight.
« Reply #1 on: 16 May 2021, 20:24:18 »
Hope it glides well.  ;)
« Reply #2 on: 16 May 2021, 21:04:38 »
It would have to. :-\
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 16 May 2021, 21:38:12 »
It makes a change from the 1930s technology that's still the standard for most general aviation.
« Reply #4 on: 16 May 2021, 21:59:10 »
The A330 can glide from Bermuda to the Azores, and that has two engines. :D
It will be fine.
Probably  ;)
« Reply #5 on: 16 May 2021, 22:19:03 »
I didn't think you were allowed to put lithium batteries in the hold?  ???  :D
« Reply #6 on: 16 May 2021, 22:43:33 »
You're not, but I think the hold is in the cabin on a whizz jet ;D
  • Chatham, Kent
« Reply #7 on: 16 May 2021, 23:40:21 »
It was recharging lithium batteries in place that caused Boeing's problems. The more aggressive chemistry of a lithium-ion  battery is what makes it more suitable for a lot of uses than other types. But, changes always come with a cost, and the need to be a lot more careful charging the things is one of them.
« Reply #8 on: 16 May 2021, 23:46:17 »
Thermal runaway anyone?
« Reply #9 on: 17 May 2021, 11:33:40 »
One day they will be covered in solor cells plus they will find a way to funnel air to create a turbine generator. :y
deviator
  • Chesterfield
« Reply #10 on: 17 May 2021, 15:06:22 »
The flight, 'Thermal' is now departing runaway 4  ;D
« Reply #11 on: 17 May 2021, 17:16:50 »
ronnyd
« Reply #12 on: 17 May 2021, 20:25:06 »
https://youtu.be/24fYrV2vCPk :-X
Hmm, just like an Omega power sounder then. :)
« Reply #13 on: 20 May 2021, 20:07:19 »
Now for something different.
It all started with multi wing flight.
https://interestingengineering.com/tri-wing-jumbo-jet-reduce-fuel-consumption-70-percent
