Author Topic: E10 Petrol Standard  (Read 4670 times)
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
E10 Petrol Standard
« on: 20 May 2021, 15:39:18 »
In the latest Straight Six News from AutobahnStormers there is an interesting article reproduced from the Mercedes Benz Club UK Magazine.
It explains the legislation from 1st September 2021 to introduce E10 petrol as standard for the current 95 octane with Super grade petrol, previously 97 octane, being classified as E5.  Importantly it gives a link to the government website to check E10 petol suitability for our cars,  www.gov.uk/check-vehicle-e10-petrol
According to that website the exceptions for Vauxhall vehicles states:
"E10 petrol is cleared for use in all Vauxhall vehicles with petrol engines, excluding:
Models with the 2.2 litre direct injection petrol engine, motor code: Z22YH (Vectra, Signum, Zafira)"
Some of you may know this already, but for me, and I suspect a lot of motorists, this is news I had not picked up on before.
It looks as though our Omega's are unaffected by this new petrol legislation.  So is this non-news or not? ??? ??? :D ;)
Re: E10 Petrol Standard
« Reply #1 on: 20 May 2021, 16:21:40 »
The high pressure pump on that engine has always been fickle when it comes to fuel quality. Most exceptions seem to be either first generation direct injection or carburettor equipped cars. Basically the ethanol destroys the seals, and also gums the passages within the carbs as it breaks down.
Higher ethanol percentage fuels will go off much more quickly than non ethanol.
« Last Edit: 20 May 2021, 16:28:18 by Doctor Gollum »
    • Grandland 1.5 diesel
« Reply #2 on: 20 May 2021, 16:54:57 »
Buy a diesel.....simples.
Diesel till I die
Lizzie Zoom
  • South
« Reply #3 on: 20 May 2021, 16:55:15 »
Ah, that goes to explain something I did not understand.
As a footnote to the article, Chris Kent explains that : "It should be noted that not all Super E5 grades contain Ethanol, Tesco being one, however this may change in the future". ;)
countrywoman
  • worcestershire
    • skoda yeti
« Reply #4 on: 21 May 2021, 09:01:18 »
On the hot rod forum it stated that the ethanol attacks ali so will eat fuel tanks , how resistant are the "rubber" fuel lines going to the tank unit ?? I do need to alter the plastic hard lines from the Omega to fit the Austin (about 2ft plus to long) so will need some e10 proof hose.
  • Online Online
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #5 on: 21 May 2021, 09:29:23 »
You can easily buy ethanol proof fuel-hose, but it's best to get a known brand from a proper, trusted bricks and mortar supplier with a decent turnover. Gates from your local truck factor or a hydraulic supplier would be a good start.
I'd be amazed if the Omega shaped hard lines are going to be of much use under your car, but that's easily sorted at the hydraulics supplier: you buy 6mm bore nylon pipe for pneumatic systems which is basically the same stuff. It's cheap and easily worked. You fit your existing fittings by warming the end of the hose with a heat gun and forcing the fitting in. Gentle bends can be done the same way.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #6 on: 21 May 2021, 12:03:05 »
I want to know what it's going to do to my lawn mower.
I like red cars
  • Online Online
  • Chatham, Kent
« Reply #7 on: 21 May 2021, 13:51:29 »
Pulling the starting cord will make bang ever and the world will end....
