Author Topic: Running x30xe with blocked off oil cooler? Possible problems?  (Read 2626 times)
calibrated
  • Croatia
    • Opel Calibra
Hi! As question stated,what could cause running without oil cooler for a short term? (Blocking of both holes on the sides of oil filter(there would be no circulation between them)
Thanks.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Why? It's there to help cool the engine, so if it's not there,,, engine will run hotter,and hot oil doesn't lubricate very well.
Hoof'land storeman.
  • Chatham, Kent
    • Ghastly 1.0l Focus
You missed out that it's a (relatively) modern engine that is supposed to run hotter than an older one.
deviator
  • Chesterfield
I have known this be done before and I didn't hear of any major issues. Now that was a Vectra B. But I'd argue the engine is better cooled in the omega due to the layout.
If it's short term, I wouldn't have an issue. The thing is, it seems like a lot of hassle for a short term fix. I believe the 2.6/3.2 had stainless coolers fitted, so if that's the problem, just buy one second hand. I will add, you need to check that the threads for the oil cooler pipes as these can strip, so check them out before buying.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
Should be fine as long as you’re not towing or hooning about.
Laying a rubber road.
Page created in 0.023 seconds with 20 queries.
