Crank Sensor Failure
Started by Lizzie Zoom, 23 June 2021, 20:04:35
Could also be a failing fuel pump.
Lizzie Zoom
Quote from: Doctor Gollum on 24 June 2021, 12:49:33
Yes, but the AA guy checked the fuel supply thoroughly and found fuel was definitely getting through every time he asked me repeatedly to turn on the ignition.  Also his tech check found nothing wrong in that respect.
But as omegod points out, whatever it is - the crank sensor must still be favourite and will be replaced when it arrives - it could well leave me stranded in a very bad place! ::) ::) :o ;)
A failing fuel pump can cause poor starting, especially at lower tank levels.
I agree that the crank sensor is a likely culprit, just be mindful that it may not be the only issue.
Neither give codes, and a weak pump will still deliver some fuel to the rail.
A faulty MAF can give similar symptoms.
All these could be posts are why diagnosis is done with live data. Anything else is a guess.
Lizzie Zoom
Quote from: Nick W on 24 June 2021, 14:34:31
Yes, indeed, and that is why I must not forget what the engines tech readings gave the very experienced AA guy, with only the crank sensor as the leading culprit as the machine, nor rev counter, did not show the engine turning even when being turned over on the key.
Enceladus
You cannot tell which sensor it is just from the loom connector. There are three sensor variants, one with a rectangular sided plug and two with oval sided plugs, in use on the sensor tails. All three sensors may fit the engine however they have different electrical resistances.
As your engine is a Y32SE V6 then the sensor required will be Bosch 0261210131 aka GM# 90540743. Just make sure that wherever it comes from it's a Bosch part with the Bosch number on it. You could try Autovaux.
The symptom you have is typical crank sensor failure. Heat eventually kills the sensor and/or the wiring tail and it stops working when hot, let the engine get cold and it works again. It'll likely get worse over time, engine cutting out when decelerating for traffic lights etc. Eventually it may not work at all.
Absent a P0355 fault code it could also be the fuel pump as DG mentioned.
Any replacement sensor needs to be square into the hole in the block. Don't rely on the screw to pull it into position. If the sensor head is not square or the gap to the reluctor ring is incorrect then the sensor won't work reliably.
Lizzie Zoom
LZ - Do n to believe what your dealer tells you. As previously stated, EPC is incorrect about 75% of the time on V6 crank sensors.
So identify yours. Or be disappointed.
I actually agree with Dr Gollum on this, get a genuine GM one from a bricks and mortar dealer.  Partly because of the number of fake Bosch sensors out there, and partly because of our regular, frequent experiences here.  All those European sites that are actually the same, but try to look like separate companies, including Autodoc, are probably best avoided if you want genuine items (which you do).
Lizzie Zoom
Quote from: TheBoy on 24 June 2021, 18:20:53
Thanks TB :y
I will find out if any other Vx dealer has them still ;)
Yours should be able to if they can be bothered  :-X
15 years ago I bought a Bosch coil pack for my Omega from a Bosch service agent. Struck me that I had a pretty good chance getting a genuine part  :)
IIRC it was about half the price of buying from a VX dealer and they had the part in stock.
The place I went to was in Luton & only sold parts, don't know how I found it now :-\
All the searches I have tried come up with indi workshops.
https://www.boschaftermarket.com/gb/en/parts/?pi_url=%2Fpi%2Fserver%2Fen%2FGB%2FBosch-AA%2FAA_WEBSITE_UK_2018%2Fcategory%2Fce_32216725%2Fproduct%2F0261210205%3Fhints%3Dtrue%26categoriesFilter%3D%26selectedCategories%3Dce_32216725#scrolldetail
https://www.boschcarservice.com/gb/en/workshop-finder.html?searchLocation=canterbury
Lizzie Zoom
Quote from: Andy H on 25 June 2021, 05:33:56
Thanks for that Andy.  Nice local link for me to follow up with. :y :y
I have a Bosch one coming, although after the wise feedback I have had I am now still after a genuine Vx one for a belt and braces approach.
I have taken note of DG's fuel pump advice, so if the crank sensors (one of them!!) do not do the triick I am onto that option! ;)
Lizzie Zoom
#27
Quote from: Doctor Gollum on 24 June 2021, 19:47:09
At my Vx dealer I deal with the parts manager who I have known for years and he has often carried out in depth research to find the genuine parts I need, including sourcing them from Germany.  When he says an item is now not available, rightly or wrongly, I believe him.
In this case he gave me a full Opel part number 1238740, product number 30494182, it's code K80 and of course confirmed the Vx number 90540743.  The Opel number is being quoted on the Autodoc Bosch sensor, along with the Vx one.  But as you all recommend I will continue to hunt for the Vx version, which I may just have found available on this forum!
Whilst writing, DG mentioned the fuel pump; where on the engine is that, as I have never replaced one on an Omega?  ??? ???
The Maintenance Guides do not seem to cover it's replacement either. ::) ::) :)
Migv6 le Frog Fan
Its in the petrol tank. Access from under the circular plate on the floor of the boot.
I would bet my months wages its the crank sensor though. Assuming its still on the original one.
Lizzie Zoom
Quote from: Migv6 le Frog Fan on 25 June 2021, 12:40:05
Thanks for that :y :y
I am hoping it is the crank sensor, but now I know at last where the fuel pump is :D :)
