Author Topic: Torque head bolts excesive?  (Read 10690 times)
olm
  • spain
    • 3.2 v6 sport estate
« on: 03 July 2021, 02:53:59 »
Hi, I'm mounting the cylinder head of my y32se and I see that the tightening is 20nm +90+90+90+15. But when giving 90 + 90 the screw no longer works and I use a large long bar, if I try to give the 105 that remain it will break. . Has someone mounted it and given that tightness?
Thanks
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Torque head bolts excesive?
« Reply #1 on: 03 July 2021, 08:16:42 »
The "90 " part is degrees (a quarter turn)  , NOT 90 NM
Lucky you stopped and asked
new bolts required now and probably a new head gasket
olm
  • spain
« Reply #2 on: 03 July 2021, 13:07:43 »
Yes, is degrees, I know, sorry for not specifying
Enceladus
  • London
« Reply #3 on: 03 July 2021, 13:34:26 »
Are you using new bolts?
Even worse, as I read it the correct spec is 25Nm + 90° + 90° + 90° + 15°. Not 20Nm ++++.
All bolts in turn in the correct spiral sequence.
Operate your torque wrench a couple of times on one of the wheel bolts before you use it on the head bolts. Might help accuracy.
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
« Reply #4 on: 03 July 2021, 13:54:30 »
It is some time since I refitted a cylinder head, and then on 4 pots.
Back in the day the tightening of the bolts was done in sequence, in a cross pattern, from middle to ends.
As a point of interest, and ready for the day I may have to do it again, but on my V6, what is the prescribed pattern tightening down gradually to full torque? ??? ??? ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #5 on: 03 July 2021, 14:18:33 »
The tightening pattern(and you loosen in reverse :y ) hasn't changed. It's like that to prevent distorting the part as the forces are applied. It's why you tighten opposite wheelbolts too. Modern heads have a lot less metal in them, usually aluminium, although the multi-pass approach means that the clamping is built up in stages.
« Reply #6 on: 03 July 2021, 14:54:25 »
... Even worse, as I read it the correct spec is 25Nm + 90° + 90° + 90° + 15°. Not 20Nm ++++.
The difference between 20Nm & 25Nm is negligible ....  ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #7 on: 03 July 2021, 15:05:18 »
using a "large long bar" on a torque wrench isn't good practice though  :o
sounds like the threads are bottomed out  :-\ or maybe have oil or coolant in  :-\
such extreme torque could distort the deck of the block round the bolt holes
clearly something is wrong
has he head been skimmed ?
using the foot/pound scale instead of newton meters  :-\
re-using stretch bolts  :-\
    • Grandland 1.5 diesel
« Reply #8 on: 03 July 2021, 15:08:17 »
I do hope his head hasn't been skimmed  ;D
Diesel till I die
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #9 on: 03 July 2021, 15:15:52 »
 ;D :P
would explain the issue  :D
it should read "has THE head been skimmed"   :-[
Enceladus
  • London
« Reply #10 on: 03 July 2021, 16:10:15 »
The bolt tightening sequence, described as a spiral sequence from the middle outwards, can be viewed here.
I would guess that an unskimmed head is 134mm, because that's the spec for X25XE and Y26SE, between the upper and lower planed surfaces. So if it's measurably less then it has been skimmed. If it was skimmed because it was warped then the material removed might be significant.
« Last Edit: 03 July 2021, 16:11:53 by Enceladus »
« Reply #11 on: 03 July 2021, 16:11:45 »
Excuse my ignorance, but would you then have to use shorter head bolts?
Diesel till I die
LC0112G
« Reply #12 on: 03 July 2021, 16:32:36 »
A cowboy might do that. I very much doubt you'd bottom out a standard new head bolt regardless of how much you skim (assuming less than 1mm). Much more likely to be the wrong bolts, or the wrong washers, or you haven't correctly cleaned out the bolt hole.
Skimming the head ALWAYS increases compression. ALWAYS. It also brings the valves into closer proximity with the top of the piston. I've no idea what the normal clearances are in our V6's, but IMV the skimming limits on heads are usually to do with maintaining compression ratios within acceptable limits.
If you've skimmed the head by more than the allowable limits then the two options are 1) find a new head, or 2) fit a thicker head gasket.
As for the torqueing sequence. It's only valid for NEW standard head bolts. I'd guess these are 8.8 grade steel? If you use a stronger steel bolt (10.9, 12.9 or ARP fancy stuff) then following the torque sequence WILL lead to tears.
« Last Edit: 03 July 2021, 16:36:45 by LC0112G »
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #13 on: 03 July 2021, 16:34:54 »
you can't skim much off a V engine head and expect the valley gubbins to fit back
« Reply #14 on: 03 July 2021, 16:44:51 »
AIUI, there are no published limits for skimming the V6 heads.
Which suggests that they shouldn't be skimmed.
Page created in 0.022 seconds with 20 queries.
