Lights flashing
Started by robson, 08 August 2021, 22:51:18
Quote from: robson on 09 August 2021, 19:25:14
Yes Andy I checked the switch support etc.but difficult to check the operation with the bonnet closed Obviously needs a meter connected
A dab of grease would tell you if it's touching the bonnet or not.
Even Ketchup would suffice...
Migv6 le Frog Fan
Or blu tack ,chewing gum etc. etc.
so, if you unplug it and the alarm doesn't sound, the bracket just needs adjusting .... upright is normally good enough
robson
I charged the battery up and all now seems ok. :y
