Author Topic: Will this part be ok for my car?  (Read 5442 times)
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« on: 09 August 2021, 14:06:39 »
https://www.ebay.co.uk/itm/234079680875?fits=Plat_Gen%3AB%7CModel%3AOmega&hash=item36803c796b:g:7FoAAOSwi0lg5SeR
             I’ve read some of the aftermarket ones are useless any used these?
Laying a rubber road.
Re: Will this part be ok for my car?
« Reply #1 on: 09 August 2021, 15:38:22 »
It will be fine ;)
Even if it only lasts a couple of years, it's cheap enough to be considered a service item...
Raeturbo
  • South Wales
« Reply #2 on: 09 August 2021, 15:41:02 »
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #3 on: 09 August 2021, 18:22:54 »
One problem I discovered many years back on a Carlton arm that had been replaced with a non gm one was that it was ever so slightly shorter in length ( bush length) so that when fitted and the nut was tightened to its stop it was still loose on the bracket.
It was rectified at the time with a suitable washer that went over the raised non threaded part of the shaft and made it tighten to its correct stiffness. This arm lasted at least 5 years to my knowledge afterwards.
Just a point to note when fitting l
Raeturbo
  • South Wales
« Reply #4 on: 09 August 2021, 18:29:36 »
Thanks👍
« Reply #5 on: 09 August 2021, 19:00:18 »
It will be fine ;)
Couple of years?
That may be enough to outlast old Rae. ;D
Raeturbo
  • South Wales
« Reply #6 on: 09 August 2021, 20:05:27 »
Watch it mate⚔️
