Pages: 1 2 3 [4] 5 6 7 8   Go Down
Author Topic: My Next car....  (Read 33468 times)
    • Grandland 1.5 diesel
Re: My Next car....
« Reply #45 on: 11 August 2021, 15:02:20 »
Nowt wrong with derv, more grunt at lower revs and higher mpg. They'll take more stick too.
And readily freezes in alpine climates, forcing you to use special alpine diesel with additives. Even that freezes below -20 IIRC. Has happened to me once, and caused me to miss my flight home. Hire car was full on pickup from Lyon airport, so short of pouring fuel down the drain to re-fill with the alpine stuff there was little I could do. Bit of a pi55er at 4AM in a snowstorm half way up a mountain.
The more grunt at lower revs is because the majority of derv cars are turbo diesel. A petrol turbo car with similar cc's can have similar torque, and usually over a wider rev range. Just needs proper anti-knock control.
Plus everyone knows derv is the devils fuel, and only for lorryists.
Well.....your options are limited. Good luck  :)
Diesel till I die
Re: My Next car....
« Reply #46 on: 11 August 2021, 17:33:46 »
I can't argue with that.
However, derv isn't suitable only for a  lorry lump.
It can also be used in a bus.....canal boat.....cement mixer.....back up generator......tractor.....road sweeper.
It's just not suitable for cars. :)
Re: My Next car....
« Reply #47 on: 11 August 2021, 17:49:17 »
If looking for a direct Omega replacement, you're shit out of luck.  There is *nothing* that meets your (and mine, for differing reasons) needs.
A compromise has to be made somewhere :(.
Given nobody has made an acceptable sub £150k RWD family lugger in the last 10 years, I suspect it's the RWD that will have to be compromised.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
Laying a rubber road.
Re: My Next car....
« Reply #49 on: 11 August 2021, 17:52:31 »
Re: My Next car....
« Reply #50 on: 11 August 2021, 18:01:47 »
Good shout :y
Failing that just get the 5.7 8)
« Last Edit: 11 August 2021, 18:05:45 by Doctor Gollum »
Re: My Next car....
« Reply #51 on: 11 August 2021, 18:11:00 »
Diesel till I die
LC0112G
Re: My Next car....
« Reply #52 on: 11 August 2021, 18:21:26 »
https://www.gumtree.com/p/lexus/2011-lexus-s3-450h-3.5-se-i-5dr-cvt-auto-estate-petrol-electric-hybrid-automatic/1408031384
You can call that an estate if you wish. To me it's an MPV.
Cracked it!  :D
I think they must be come contaminants in the water down there. It appears to be affecting your visual abilities, not to mention sense of taste. The colour, not to mention the shape.
Good shout :y
My Australian Bil suggested a Holden Caprice (WM) 6.2 litre - rekcons I can import one for circa £17K. He's as mad as a wombat on speed, and I see the infection is spreading faster than CV19 ::)
LC0112G
Re: My Next car....
« Reply #53 on: 11 August 2021, 18:29:49 »
Finally - someone saying something sensible. Oh Sh1t it's Lord Opti saying it. Either he's suddenly become sane, or I've gone nuts.  :D
Re: My Next car....
« Reply #54 on: 11 August 2021, 18:35:08 »
So he's saying it's suitable for cars? Sensible fella  :y
Diesel till I die
Re: My Next car....
« Reply #55 on: 11 August 2021, 18:36:04 »
Oh...not suitable  ;D
Diesel till I die
Raeturbo
  • South Wales
Re: My Next car....
« Reply #56 on: 11 August 2021, 18:38:04 »
Cracked it!  :D
Good shout :y
[/quote
               &0llocks then, find your own crock of shit🤣
Re: My Next car....
« Reply #57 on: 11 August 2021, 18:39:03 »
Cracked it!  :D
That's failed 3 MOT's in 8000 miles ;D
Bah nothing serious and all due to lack of use!  ::)
It needs a good run that's all.  A trip to the Alps should do it.  :y
Re: My Next car....
« Reply #58 on: 11 August 2021, 18:39:37 »
Cracked it!  :D
Wheel bearing failure due to lack of use?
Diesel till I die
Re: My Next car....
« Reply #59 on: 11 August 2021, 18:40:59 »
Keep your reading glasses close to hand, old boy. :-* :-* :'(
Pages: 1 2 3 [4] 5 6 7 8   Go Up
Page created in 0.038 seconds with 20 queries.
