Author Topic: Cannot Find Astra J 1.6 A16XER (115 hp) 2010 Crank Locking Slot  (Read 3781 times)
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
https://www.omegaowners.com/forum/index.php?topic=147169.15
My old topic where both DG and dave the builder informed where to find this slot for locking crank (between Dec. 14-16 2021). Dave even enclosed the picture but this is picture disappeared from the topic.
I cannot find the slot in the bloc. I was lookin for it around oil filter area and around lower engine mount area but cannot find it. Do I have to go under the car or can I see from above. What is the direction to put the locking tool in? Is it the direction from the water pump end to clutch end or from front to back. Strange to be that blind. Could you help, should start the job on Friday and be ready on Saturday (same week).
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Cannot Find Astra J 1.6 A16XER (115 hp) 2010 Crank Locking Slot
« Reply #1 on: 24 August 2021, 10:47:59 »
from underneath it's a gap between the sump casting and block ,near the oil level sender .front engine mount (oil filter is above it)   ;)
the locking tool goes in the gap and into a slot in the flywheel(and you need to rotate engine to bang on target to get the lock in)  lock is held in place with a bolt you need to remove, as per pic
sorry but the pic is massive and i don't know how to resize ,just copy it to your pc to view  ;D
polilara
  • Finland
« Reply #2 on: 24 August 2021, 11:01:18 »
Thanks a lot dave, I copy the picture now. It's a long story, first i had to do the timing belt last Christmas, then Easter and now on Friday. Timing belt still working...
