OEM Gasket Set
Started by fcc-pt, 28 August 2021, 12:40:28
fcc-pt
Quote from: Nick W on 08 September 2021, 12:12:53
Quote from: fcc-pt on 08 September 2021, 12:05:55
The thermostat is new I had it replaced a couple thousand km same with water pump bronze impeller and the timing belt kit as well.
It kills me to replace everything...
Will I need a straight edge of 400cm and a feeler gauge to check the heads for flatness expensive tools...
A good quality 300mm steel rule is more than good enough to check the heads. That's a £10 tool that you probably already have. Use it with a small torch. Any head that fails that test is then checked with the feeler gauge to determine whether you get your machine shop to check it with dedicated and precise tools/procedures.
Thank you so much for the tip that was smart.
