Author Topic: ME 262  (Read 4317 times)
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
ME 262
« on: 08 September 2021, 21:07:39 »
Anybody find something odd about this?….
           https://youtu.be/7S88FsFE5EE
Laying a rubber road.
Re: ME 262
« Reply #1 on: 08 September 2021, 22:00:23 »
How so?
Olympia5776
  • Ireland
Re: ME 262
« Reply #2 on: 08 September 2021, 22:06:24 »
Don't see any jet wash or heat dissipation from the engines .
Re: ME 262
« Reply #3 on: 08 September 2021, 22:56:36 »
Look closer.
Also, they don't run at anything like the temperature of modern jets.
Don't forget that the image will be distorted by distance and heat shimmer between the camera and the aircraft.  ;)
Raeturbo
  • South Wales
Re: ME 262
« Reply #4 on: 09 September 2021, 00:08:22 »
               Yes that’s what I noticed not a single blade of grass is moving
LC0112G
Re: ME 262
« Reply #5 on: 09 September 2021, 09:47:19 »
I've seen it fly twice, so either I'm in on he conspiracy or you're all making something out of nothing. Pretty sure it's a replica owned by EADS/Airbus and operates from their Manching factory site just north of Munich. I also believe it's not using the original engines - it's using American J85's more commonly used on cold war small jet fighters.  Doesn't fly much and usually has the national insignia and Swass Stika symbols covered due to German laws about Nazi symbols.
Raeturbo
  • South Wales
Re: ME 262
« Reply #6 on: 09 September 2021, 10:09:04 »
I appreciate that Malcolm and love the aircraft but why is the grass not being disturbed? It’s puzzling me👀🤔
LC0112G
Re: ME 262
« Reply #7 on: 09 September 2021, 10:42:13 »
Parallax. The camera is filming from about 30 degrees off the nose. The red/white fire hydrant? in the background is level with the left hand edge of the tarmac/concrete, so the jet efflux would be well to the right of it (as we look). We only get one view of the shrubbery directly behind it (at about 2:00), and it appears the jet is about 20m from the edge of the tarmac, and so probably 25-30m from the taller grass. You don't need much puff to get a lightweight fighter moving (two people could probably push it) so the engines are only revved up to just above idle to get it moving.
If the engines had been running at full chat the grass and trees would be moving in the jet blast. But at idle power it would be un-noticeable. You can often get that close behind jets at airshows, and you don't really notice the jet thrust above the noise and smell of burnt kerosene .
Raeturbo
  • South Wales
Re: ME 262
« Reply #8 on: 09 September 2021, 11:25:12 »
Thanks👍 It needs a pair of P&W J58 that will move the shrubs😂
https://en.m.wikipedia.org/wiki/Shock_diamond
Lovely picture which I’m sure you’ve seen before😎
« Last Edit: 09 September 2021, 11:27:29 by Raeturbo »
LC0112G
Re: ME 262
« Reply #9 on: 09 September 2021, 11:42:27 »
This one always makes me chuckle - and it's a J85.
https://www.youtube.com/watch?v=T4bn1WG5LS0
Raeturbo
  • South Wales
Re: ME 262
« Reply #10 on: 09 September 2021, 12:49:48 »
Ha ha, decided to go it alone :y
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
Re: ME 262
« Reply #11 on: 10 September 2021, 18:27:56 »
I have always liked the look of those aircraft, but thank God, Hitler was not able to put enough in the air due to lack of fuel, spare parts, and the pilots to fly them, along with the maniacs initial hesitation to go all out for jet technology.
If they had been able to be used in 1943 WW2 just may have ended very differently, or at least been lengthened by years! :o :o
redelitev6
Re: ME 262
« Reply #12 on: 10 September 2021, 19:04:14 »
If they'd had the V2 rockets at the start of the war , things would have been different
Lizzie Zoom
  • South
Re: ME 262
« Reply #13 on: 10 September 2021, 20:27:29 »
Indeed!!  Part of the number of if’s, buts, and maybe’s of WW2 that could well have produced a very different outcome ;)
Raeturbo
  • South Wales
Re: ME 262
« Reply #14 on: 10 September 2021, 21:07:55 »
No ifs or buts…. They picked a fight they didn’t want with the wrong country, after that their plans went tits up👍  🇬🇧🇬🇧🇬🇧🇬🇧 No matter what they done they were doomed from that point We will never surrender 👍👍👍👍
