Author Topic: Missing  (Read 3481 times)
jacko
  • london
    • vauxhall omega 2.2
Missing
« on: 18 September 2021, 14:21:46 »
Hi chaps
Just replaced rocker gasket new plugs
Air filter
Running awful on tick over have two codes
What could this be
P1700
P1781
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
Re: Missing
« Reply #1 on: 18 September 2021, 14:31:14 »
Laying a rubber road.
Re: Missing
« Reply #2 on: 18 September 2021, 15:07:10 »
Nonsense.
Replace the Cam Sensor with a genuine one from a Vauxhall Dealer you genuinely have to walk into.
And report back.
On that engine, those codes have absolutely nothing to do with the gearbox or its ecu.  ;)
jacko
  • london
Re: Missing
« Reply #3 on: 18 September 2021, 15:28:28 »
So doctor your saying those codes are cam sensor to be clear 👍
Re: Missing
« Reply #4 on: 18 September 2021, 16:39:01 »
Exactly  :y
That's to say the codes suggest imminent gearbox death.
The actual cause is a failing cam sensor.  ;)
jacko
  • london
Re: Missing
« Reply #5 on: 18 September 2021, 17:10:19 »
Thanks doc will post when I have replaced it  :y
Viral_Jim
  • Telford
    • Too many, mostly broken
Re: Missing
« Reply #6 on: 22 September 2021, 11:38:08 »
Good luck with the replacement, I found it to be a complete pig on my 2.2, one of the most awkward jobs I've ever done.
Enceladus
  • London
Re: Missing
« Reply #7 on: 22 September 2021, 12:32:20 »
There's a "How To" guide here.
Viral_Jim
  • Telford
Re: Missing
« Reply #8 on: 22 September 2021, 14:24:54 »
Ahh, I meant the crankshaft position sensor   :-[. The cam sensor is not so bad.  ;D
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
Re: Missing
« Reply #9 on: 22 September 2021, 14:42:28 »
I presume all the vacuum and wiring connectors that were undone for the cam cover change have been double-checked, could just be an air leak.
p.s. I'm not an expert on 2.2s by any means
Page created in 0.061 seconds with 20 queries.
