Pages: 1 [2] 3  All   Go Down
Author Topic: Steering idler  (Read 12313 times)
  • Online Online
Re: Steering idler
« Reply #15 on: 07 October 2021, 12:41:49 »
Take a 21 mm socket as well, just in case the idler arm to shaft nut is larger :D
21mm? Did you mean 19mm?
You'll also need a pair of ball-pein type hammers. Hit the ball joint at two opposite points simultaneously to (shock) separate the idler end from the steering. Best done from underneath and with some downward force applied at the same time, wedge in something like a chisel or big screwdriver. So a three handed job in an area with room for one.
Presumably you should be able to use a joint splitter, but I don't think a standard off the shelf splitter will work. It's something more exotic. Perhaps a special tool or maybe just a fork chisel type tool. I can't remember. Somebody must know?
Nope, I meant 21...19 was covered in my previous list.
It probably won't be required, but it's better to have it just in case than find out you need it. Most of the Omega suspension from the factory only requires 16/18 mm but I know from experience that aftermarket stuff varies considerably, and as Steve only has one arm, have the extra socket/spanner might just save him a trip ;)
Also it's been about ten years since the last one I changed.
  • Online Online
Re: Steering idler
« Reply #16 on: 07 October 2021, 12:44:20 »
To Malcolms point, under the circumstances, it might be easier for Steve to remove the bracket and pop the idler off with it held in a vice...  :-\
LC0112G
Re: Steering idler
« Reply #17 on: 07 October 2021, 14:05:00 »
But then you've got to separate the other end of the centre steering link from the arm on the power steering box. Or take the power steering box off.
  • Online Online
Re: Steering idler
« Reply #18 on: 07 October 2021, 14:10:21 »
See the post previous to my reply to yours ;)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Steering idler
« Reply #19 on: 09 October 2021, 12:49:41 »
Afternoon men. I hope ur all well. Got this replaced this morning. Took about three minutes 😂 I undid nut securing it to the shaft. The idler then slid down off said shaft. I then held centre track rod firmly with my, err, stump lol (you folk can simply use ur second hand 😂😂😂) and gave the idler a wallop where the BJ goes through it. Came straight off.
Note though it was super easy cos everything had been copper jizzed on last time I did it 😃
RIP Paul Lovejoy
  • Online Online
Re: Steering idler
« Reply #20 on: 09 October 2021, 13:18:40 »
Three minute BJ?  :o Is that good or bad :D
Glad you didn't have any issues with it  :y
Webby the Bear
  • Northampton
Re: Steering idler
« Reply #21 on: 09 October 2021, 22:05:30 »
😂😂😂 do it four times in three minutes 😂😂😂😂😂
RIP Paul Lovejoy
Re: Steering idler
« Reply #22 on: 10 October 2021, 09:20:27 »
Impressive Webby, I've spent 30 mins before trying to separate it from the centre tie rod.
For others, I found 2 4lb club hammers the best way, knocking from opposite sides simultaneously, sometimes with a wedge between the tie rod and the idler to add pressure.
No standard off-the-shelf splitter fits.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: Steering idler
« Reply #23 on: 10 October 2021, 09:26:41 »
Puts me to shame. I had a half hearted attempt at changing mine a few months ago but gave up half way through to to a case of CBA.
I really struggle to find much motivation to work on cars recently. If its a permanent affliction I will need to think about clearing out the fleet and buying one sensible piece of white goods.  :(
Re: Steering idler
« Reply #24 on: 10 October 2021, 11:09:57 »
I sympathise. Its taken me 8 months to change a shagged headlight on the battlebus...
...which reminds me, I really need to have another look for headlights for the BBP, although the chinky takeaway containers and sikaflex is holding up well.
Webby the Bear
  • Northampton
Re: Steering idler
« Reply #25 on: 10 October 2021, 20:11:58 »
Don’t get me wrong I very much have CBA moments especially on this car. I sort one thing and then it’s something else. And this cycle just repeats 😢 my Mrs has 18 plate Hyundai. She swaps it for new one next year and only thing she’s had in 2 1/2 years was a slow puncture. Makes u wonder doesn’t it 🤦‍♂️🤦‍♂️🤦‍♂️
RIP Paul Lovejoy
countrywoman
  • worcestershire
    • skoda yeti
Re: Steering idler
« Reply #26 on: 11 October 2021, 08:36:18 »
But why would you want a piece of boring plastic crap?
Webby the Bear
  • Northampton
Re: Steering idler
« Reply #27 on: 12 October 2021, 07:13:01 »
That’s a very good point. I went to the IOW recently and saw zero omegas. Therefore love it or hate it it’s now rare which I think is cool. On he same trip I saw two Morris minors, one Lamborghini and three astons 😂
RIP Paul Lovejoy
  • Online Online
Re: Steering idler
« Reply #28 on: 12 October 2021, 12:43:32 »
I bet none of them were silver ;D
Webby the Bear
  • Northampton
Re: Steering idler
« Reply #29 on: 13 October 2021, 18:42:40 »
😂 no they weren’t!
RIP Paul Lovejoy
Pages: 1 [2] 3  All   Go Up
Page created in 0.34 seconds with 20 queries.
