Author Topic: Failed Jump start  (Read 11450 times)
fudgee
Failed Jump start
« on: 06 October 2021, 16:08:28 »
Hi everybody I hope your all well and good.
My 03 plate 2.2 cd auto has been sitting idle for about 3 months (don't ask......my life's a mess at the moment  :-\ ) so obviously the battery has gone flat.
Today I attempted to jump start it but no joy.
Once I attached the jump leads I left them on with the other cars engine running for a good ten minutes before attempting to start my omega.
As soon as I attached the leads my dashboard lights came on as expected, however once ten minutes had passed and I tried to start it I heard a click and the dashboard died and it didn't attempt to start at all just completely dead.
I left it charging for another 5 minutes but still no lights or life at all.
I then detached the jump leads from my battery and immediately put them back on again and that made all the lights and stereo come on again.
I left it charging for another 5 minutes including me revving the other cars engine and the exact same thing happened again when I tried to start it.
Removed the jump leads and put them back on the same as before and once again the lights and stereo came on and then died when I tried to start it.
This happened a couple of more time before not even removing the leads could get any life into it and now it's dead completely  :'(
I checked the fuses under the steering column and none have blown and also what is important to point out is the both the battery and alternator are brand new. They were both replaced a couple of months before I parked the car up for the last time with no issues whatsoever.
Help please!!!
Re: Failed Jump start
« Reply #1 on: 06 October 2021, 16:12:54 »
Primary fuses live in the box above the battery.
However, if the battery isn't taking a charge, you probably need a new one. Find the receipt and take it back.
fudgee
« Reply #2 on: 06 October 2021, 16:23:02 »
Thank you I will check them once I'm home from work and see if any have blown.
It's good to hear from you again by the way.
I hope your well and everything is going okay at the airport  :y
« Reply #3 on: 06 October 2021, 16:26:34 »
    There's an exceptional starting/charging guide in the Maintenance Guides... If you have access to an assistant and a multimeter, follow the guide through.  :y
    Although my money is still on the battery.
    Slowly but surely thanks, finally unfurloughed... So there's that :y
fudgee
« Reply #4 on: 06 October 2021, 16:31:01 »
Glad to hear it :y....and I'll give that guide a look!!
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #5 on: 06 October 2021, 18:43:37 »
I'd try a decent set of jump leads as well. My really old jump leads are made from forklift charging cable, which is very similar to the cables we have at work  ::) , and I can honesty say that once hooked up it's as if the donor car battery is on the dead car. There is so little loss of voltage through the leads that the dead car will spin over the same as the donor car, with no build up charging time.
You may have other issues with it but trying decent jump leads is worth a punt.
iansoutham
  • SE London
    • Omega 2.0 m/f/l est CDX
« Reply #6 on: 07 October 2021, 04:04:12 »
I would suspect that the battery has gone completely flat so is taking most of the power instead of the car. What I normally do is put the positive on the battery and the negative on the engine block somewhere )like a lifting eye). That can sometimes make enough of a difference. As other advice though, make sure the jump leads are good and turn EVERYTHING off on the car being started.
« Reply #7 on: 08 October 2021, 09:43:08 »
Take the battery out and charge it overnight.  :)
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #8 on: 08 October 2021, 09:50:38 »
Remove the battery and put the battery off the other car on it to see if it starts then. That will let you know if it’s the battery or not before trying anything else.
Laying a rubber road.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #9 on: 08 October 2021, 13:17:55 »
You'll go a long way with common sense like that  ;D
fudgee
« Reply #10 on: 08 October 2021, 16:31:54 »
Hi guys.
I borrowed my friend's battery charger and left it charging overnight. Now there's power in the car and when I turn the key the engine is now attempting to turn over but it won't fire up  :-\
It was running without fault before I parked it up so its a strange one. Plenty of fuel in there.
Any suggestions?
I'm with the AA Thankfully so if no joy I can get it towed to my local mechanic who I've used for years and I trust him but would obviously prefer to try and sort it myself.
Thanks  :y
« Reply #11 on: 08 October 2021, 17:02:42 »
Does the fuel pump run briefly when yo turn the ignition on?
fudgee
« Reply #12 on: 08 October 2021, 17:21:15 »
Doctor Gollum I'm not sure how to tell...I know that makes me sounds thick!
The engine was trying to turn over. I could feel a vibration through the drivers seat as it was trying to ignite. Just wouldn't fire up
« Reply #13 on: 08 October 2021, 18:34:21 »
First, how much fuel is in it and is the car level? Saloons aren't as bad in this respect but can still struggle with slopes and very low fuel ;)
Assuming that the car is level with at least a quarter tank try this:
With the aid of the lovely Debbie McGee, place a finger on each of the purple relays in the engine fuse box... Then have them turn the key one position at a time.
As the key goes from 1 - 2, you should feel one relay click on briefly and hear the faint buzz from the fuel pump, as the key goes to crank, that relay should then switch off and as the engine spins up, the second relay should click on. Once it fires the first relay should kick back on.
If that mostly happens, and it still doesn't start, the give the bottom of the tank a slap whilst the car is cranked.
And report back  :y
fudgee
« Reply #14 on: 08 October 2021, 18:49:17 »
Thanks Doctor!
I live on my own and there's nobody around at the moment so I'll try and get somebody to help me over the weekend.
The car is level but there's not a quarter of a tank in there though. The fuel light is not on yet but probably not far off it coming on and the trip computer says there is 36 miles left?
Even though there should be enough fuel in there to start,  is the fact that it was not started up for a couple  of months affecting the lowish fuel in some way then possibly?
Thanks for your help by the way as always  :)
Page created in 0.03 seconds with 20 queries.
