Running air lines in a garage... push fit?
Started by Viral_Jim, 12 October 2021, 10:52:15
Given my history of things going wrong in the garage, I decline to advise either way ;D
I wont even use push fit on water  ;D
But water fittings for an airline is questionable, airlines often have oil in them and you need seals in the fittings capable of withstanding exposure to the oil.
Keith ABS
 On a site a few years ago, all the mains water in the building was being preasure tested overnight after being pumped up to 20bar. It dropped to -17c overnight. every fitting blew out and it flooded the floor being tested. Plastic pipe and fitting specialy designed for air are made. I would strongly advise going that route. The old way was to use steel threaded pipe and in some small establishments, copper pipe. Plastic is now the norm
