Author Topic: Power steering hoses.  (Read 8664 times)
Re: Power steering hoses.
« Reply #15 on: 24 November 2021, 08:35:56 »
Enceladus
  • London
« Reply #16 on: 24 November 2021, 13:32:56 »
Power steering is Dexron iii.
« Reply #17 on: 24 November 2021, 15:13:03 »
Same as the slushbox ;)
addy
  • County Durham.  UK
    • 2.6 CD Saloon 2ltr omega
« Reply #18 on: 28 November 2021, 08:34:57 »
Thanks for all the help. I bought some proper hydraulic hose and some decent jubilee clips. I cut out the old compression fitting, that you can see in the picture. Cleaned up the metal pipe then fitted a piece of the hydraulic hose and tightened the jubilee clips, until they wouldn't tight no more but the fluid was still sprayed out.  So in the end bought a 10mm water compression fitting from screwfix and tried that. It seems to be working, just got loads of air in the system so go to get it out. I was looking how the pipe routes, it looks like the radiators have to come out, to allow the complete pipe to come out from both sides. Or is can it be removed without removing the radiators, so I can get a new one made at a hydraulic place?
Thanks again for the help.
Addy
Drives 1995 2.0ltr CD Estate.  2002 2.6 CD saloon
« Reply #19 on: 28 November 2021, 12:08:46 »
It only runs on the right of the radiator.
addy
  • County Durham.  UK
« Reply #20 on: 28 November 2021, 12:20:26 »
When I traced the metal one in the picture, the passenger hand side goes to the steering pump. The drivers side goes over the chassis rail and looks like it goes to the steering box.  I thought if I undid both ends, I could of manouvered it out, without removing radiators and other stuff around them.
« Reply #21 on: 28 November 2021, 14:09:03 »
V6 might be different then :-\ I thought it looped across the bottom of the condenser/front lower cross member...
addy
  • County Durham.  UK
« Reply #22 on: 28 November 2021, 16:23:50 »
There is another pipe under the metal one that goes from one side to the other. It also has hydraulic rubber hose and fittings that go to it. I thought that I had got one, but it was off a 2.2 that is different again. I did try the rubber hydraulic hose and proper clamps, but it blew the fluid out, so as said fitted a compression fitting which seems to work, so is the metal one a high pressure line?
« Last Edit: 28 November 2021, 16:26:52 by addy »
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #23 on: 28 November 2021, 16:53:21 »
I think there is confusion here  :-\
 autobox cooler is a loop ,
PAS is 2 pipes ,high and low pressure
https://vauxhall.7zap.com/en/car/v94/l/0/18-1/
addy
  • County Durham.  UK
« Reply #24 on: 28 November 2021, 18:09:05 »
The metal pipe is the one that was leaking at the joint, on the left side as in the photo. The fluid definately came out under alot of pressure. It comes from the front of the steering pump, then across the front of the car then joined to the pipe coming from the left side, with what looked like a compression fitting.
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
« Reply #25 on: 28 November 2021, 19:02:19 »
Any help? Nothing in the cooler group needs to be removed. (V6).
Omega 2.5 V6 Facelift Estate.
addy
  • County Durham.  UK
« Reply #26 on: 28 November 2021, 22:19:04 »
Thanks Tick Tock
So just have to remove bumper. I see on your picture that the pipes are different again to the 2.6. In that there is no connector on the top pipe, as mine has where the pipe from the steering box, comes down to meet the one going across the front. Your picture looks like the engine is a 2.5? I wonder if at a push the 2.5 one would fit from the steering pump to the steering box?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #27 on: 28 November 2021, 22:39:10 »
IIRC the power steering pump is slightly different between early and late V6s  :-\
so that might make the connections wrong perhaps .I don't know
just a cautionary note
addy
  • County Durham.  UK
« Reply #28 on: 28 November 2021, 22:58:24 »
Thanks Dave the Builder for the info.
Looks like will be getting one made up hopefully. At least I was able to move the car in the drive, as got builders in the next few days.
Page created in 0.049 seconds with 20 queries.
