Author Topic: Worth a punt for extra grunt?  (Read 3205 times)
« on: 19 November 2021, 12:27:22 »
£100 off at present. £229 instead of £329.
Tuning box and not a bespoke remap.
Likely to work or snake oil? I tried something similar from Superchips a while back that made absolutely no difference, so I sent it back for a refund.
Which engine parameters are changed with a remap/tuning box?
https://tdi-tuning.com/en-gb/car/vauxhall/signum/28-turbo-v6-ecotec-246-bhp-250-ps-184-kw-350-nm-258-lbft/crtd4-uni-channel-petrol-tuning-box-chip
Re: Worth a punt for extra grunt?
« Reply #1 on: 19 November 2021, 12:53:02 »
Well it should double the value of your car M'lud!  :y
« Reply #2 on: 19 November 2021, 12:54:25 »
With that gearbox? I wouldn't. :D
The ecu from the Insignificant VXR would potentially offer 320 bhp. Likewise the Vectrum VXR, 280 bhp. If you must...
« Reply #3 on: 19 November 2021, 13:08:50 »
I'm dubious because the Superchips jobbie sent the car into limp home mode every time I gave it some welly.
« Reply #4 on: 19 November 2021, 13:10:35 »
That's probably because it's trying to protect the gearbox.
« Reply #5 on: 19 November 2021, 13:14:59 »
Superchips Bluefin it was called.
It just made the car undrivable, so back it went to Superchips.
« Reply #6 on: 19 November 2021, 13:16:14 »
So £20,000 then. :P :P :P :P
« Reply #7 on: 19 November 2021, 13:22:08 »
It fools the ECU into thinking the fuel pressure is lower resulting in a a longer squirt of fuel by the ECU, it probably also adjusts the MAP value down such that the turbo boosts to a higher pressure to get the extra air in (it might fiddle with MAF also, but this is rarely the case) .
Isn't yours an auto?
« Reply #8 on: 19 November 2021, 13:27:26 »
6 speed ZF auto. :y
« Reply #9 on: 19 November 2021, 13:31:35 »
The early 2.8T has a paltry 230 BHP. My car is the later model with 250 BHP.
Still a very under stressed lump though with only 89BHP per litre from a turbo engine.
« Reply #10 on: 19 November 2021, 13:35:08 »
No real issues with that box, the early ones had cooler issue and the engine coolant got dumped into the box killing it, nothing of massive concern on your era
« Reply #11 on: 19 November 2021, 13:37:58 »
I'm tempted to 'give it a go'.......I have 30 days to send it back for a refund if it all goes tits up.
« Reply #12 on: 19 November 2021, 13:42:48 »
It is a good box.
The ZF 8 speed auto on my 5.0 XFR was brilliant dealing with 530 BHP and 550 FT LB of torque with ease.  Being a a torque converter rather than 'double clutch' jobbie I thought the changes would be slow and ponderous.
Nope....more than fast enough, and very smooth also.
« Reply #13 on: 19 November 2021, 13:48:42 »
There is no better box at the moment than the ZF8, thats why everyone uses it (well, except Merc....)
LC0112G
« Reply #14 on: 19 November 2021, 13:56:43 »
I have the source code for several variants of the Superchips code for the LC. They claim 500 BHP (up from a standard 377 BHP).
There were minimal changes in any of the maps. What they did was increase the "target boost" levels at WOT from 7-10psi (depending on RPM) up to 15psi. In very rough terms 50 percent more air in is a 50% increase in power out - assuming the injectors can supply sufficient fuel to burn all that extra air.
Given that this isn't a full remap, I'd expect this to be similar.
