Pages: 1 2 [3]  All   Go Down
Author Topic: E10 and lawnmowers  (Read 9940 times)
Re: E10 and lawnmowers
« Reply #30 on: 07 December 2021, 11:49:12 »
Friends of ours have plastic grass horrible stuff, mind he is one lazy bastard.
A good pal of mine does as well.  He spent good money on it, and it does look fantastic to be honest.
But as DG (jokingly?) alluded to, he has to regularly get the vacuum out on it, so probably not labour saving.  Though arguably its quicker and less effort to run a cordless dyson over it than faff around with poxy electric mowers.
Two things I enjoy doing are looking after my lawns & cleaning my vehicles, would never consider plastic grass awful stuff, stands out a mile that it's fake.
I have to say, my mates down look like freshly mown lawn.  By far the best I've ever seen.  Its not really until you touch it that its obvious its not grass.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #31 on: 07 December 2021, 13:23:02 »
Slabs don't need mowing , unless you lay them really badly  :D
« Reply #32 on: 07 December 2021, 13:40:33 »
I have a largish lawn and cut it with a Bosch electric mower.  :)
I reckon by the time you guys have faffed about getting your mowers going in the spring, I've done mine and am sat back with a cold beer admiring my handiwork!  8)  :y
I bet mine has started, cut both lawns, and is put away before you've even finished pissing around with an extension lead ;)
You've just lost your money!  ;D
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #33 on: 07 December 2021, 14:12:20 »
Talking to an elderly couple in Saffron Walden a couple of years ago and they were on their second one, the first got nicked.  :D Must admit that it did look good. They also now have CCTV.
« Reply #34 on: 07 December 2021, 15:33:19 »
The hotel I stay at in Gran Canaria had a cosmetic refresh in 2017/18. One of the changes was the covering of the tiles on the sun terrace around the pool and the balconies with artificial grass.
This year it seems to be weathering well and is much nicer than walking on scorchio tiles to get to and from the pool.
The hotel is pretty good on landscape maintenance, (especially given their price point) and not only are the palms and flower beds kept tidy, the 'grass' on the terrace is cleaned/refluffed/hoovered regularly. I have only seen it done once, but if they do it once a month or so and you're only there for a week or two or out when they do it, you'll obviously not see it. I suspect the balconies are done by the maids. With a hoover.
A chap down the road had some fitted next to his driveway so that he could park on it without trashing the grass as an alternative to gravel.
Not sure if it's a local ordnance, or if it is a national one, but you can't simply pave an area without installing a certain amount of drainage for a given area, whereas gravel or artificial grass makes for a low maintenance cosmetic solution and doesn't affect drainage.  :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #35 on: 07 December 2021, 17:00:55 »
you can't ,without planning permission ,pave a large area with NON permeable surface like concrete etc but there are special block paving pavers etc that allow drainage that are allowed
You also can't change (significant area) of the height of the ground  + or - 300 MM without Planning.
Rules to reduce flooding due to increased rainwater run off .
    • Grandland 1.5 diesel
« Reply #36 on: 07 December 2021, 17:12:10 »
The rain passes straight through my block paving. Not even the smallest puddle.
Diesel till I die
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #37 on: 07 December 2021, 17:16:23 »
what about round the toilet pan ?  :D
« Reply #38 on: 07 December 2021, 17:17:50 »
Only if I can't be arsed putting the light on.
Diesel till I die
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #39 on: 07 December 2021, 17:21:30 »
Pissing on the floor is an art..😂😂😂
Pages: 1 2 [3]  All   Go Up
