Old cars - investment.
Started by Varche, 22 December 2021, 19:04:10
Raeturbo
Mustang just as bad as a Capri no handling no brakes little go.👍👍
Laying a rubber road.
Raeturbo
#76
And on the other hand
       https://youtu.be/UPKB4Kz5jRo
Quote from: Raeturbo on 26 December 2021, 14:30:19
        https://www.google.co.uk/search?q=ford+capri+handling&ie=UTF-8&oe=UTF-8&hl=en-gb&client=safari#fpstate=ive&vld=cid:24319062,vid:UPKB4Kz5jRo,st:0
The last one I had anything to do with, I bought most of this list while the owner was driving it home from Wales:
From Rally Design
145lb -2" front springs
new TCAs with poly bushes
poly anti-rollbar bushes (for the later 24mm W-bar)
poly rack mounts
poly bushes for the rear springs, anti-rollbars and handbrake linkage
Basic KYB shocks
1" lowering blocks
stuff we already had:
2.8i struts
good 2.8i rear springs
7" wide seven spoke 2.8i wheels
other stuff we had to buy:
Caprisport axle location kit
That lot, along with a front chassis brace took a couple of hours the following day. This car was a 2.0l, but it works well on a 2.8i too. It gives predictable handling, long life for the suspension bushes(just like an Omega, the stock TCA rubber bushes don't last long) and retains an acceptable ride - this setup rides better than a stock mk1 Focus.
Raeturbo
Yes Nick👍
                      I've changed the link too as the first one didn't work :y
BazaJT
I believe a popular brake upgrade[for the bigger engined Capris at least]was to fit the front calipers from the BL Princess.
Quote from: BazaJT on 26 December 2021, 18:22:16
It had real problems:
the caliper was designed to go under a 14" wheel, so you had to grind the top. The castings were variable, which made many of them dangerously thin - after one of mine blew the seal out, we all reverted to M16s
it's meant for 257mm diameter discs but Capris are 247. Chamfering the edges of the pads isn't a particularly good solution....
The Capri's brake problem isn't a poor caliper, but the inadequate 247x20mm thick vented disc. If you fit a bigger caliper and aggressive pad to them, they last about 5 minutes. And you regularly boil the wheel bearing grease.
They're bloody heavy!
These days the calipers are outrageously expensive, and there are better options. The RS Turbo 260x24 vented disc needs the hub circumference turned down slightly and the disc mounting ears removed, and brackets to fit the matching caliper aren't difficult. That gives a suitably improved disc, that's now clamped between the hub and aluminium wheel which acts as a good heat sink
Varche
Quote from: Varche on 27 December 2021, 10:23:12
Here is one to put away for a few years.
https://www.ebay.co.uk/itm/294634763052?hash=item449999b32c:g:eOcAAOSwm15hXFZs
Only £8k
IIRC the owner (Ian??) was member here at one time .... his Dad (Geoff had a beautiful Senator)
