Author Topic: Management light.  (Read 6885 times)
Omega Nige
  • Oxfordshire
    • Omega 3.2 V6 Elite
Management light.
« on: 30 December 2021, 20:56:12 »
Hi all, after all the work, I have another light appear. It's the car with the spanner. It came on when I went over a pot hole, seemed to be the rear end. Plugged in my reader and no codes. Cleared and it came up again. Checked for lose wires  up only found a connector on rear suspension flapping around fixed with a cable tie. Stripped and cleaned the earth strap just in case. Cleared with no codes found. Light is back! Any suggestions as to where to look next? Thanks 😊
Re: Management light.
« Reply #1 on: 30 December 2021, 21:34:51 »
The suspension or headlight level sensors won't produce an EML event.
Have you tried the pedal trick?
Omega Nige
  • Oxfordshire
« Reply #2 on: 30 December 2021, 23:04:42 »
Did the peddle trick code 0330  :)
« Reply #3 on: 30 December 2021, 23:28:14 »
Bank 1 knock sensor...
Any recent work done?
« Reply #4 on: 31 December 2021, 12:04:11 »
P0330 is actually Bank 2 knock sensor.
Most likely unrelate to the pothole, as the wire doesn't go in a place it could get damaged by the road.  The normal reason for Bank 2 is it getting trapped under the cam covers during any cam cover work, though could be related to any work around the electrics tray above the 2/4/6 coil pack.
Omega Nige
  • Oxfordshire
« Reply #5 on: 31 December 2021, 12:20:51 »
Is bank 2 knock sensor behind the alternator? I took off the serpentine tensioner and trapped the wire for the sensor when refitting it. I repaired the wire though so it may be that!  ;D
« Reply #6 on: 31 December 2021, 12:32:23 »
Bank 2 is the other side, hence that its usually cam covers.  Bank 1 is the alternator side, and catching in the aux belt is the usual cause.
Omega Nige
  • Oxfordshire
« Reply #7 on: 31 December 2021, 12:36:37 »
Thanks, I have fitted new cam cover gaskets so that will need to be investigated! How much will I have to take off?  :o
« Reply #8 on: 31 December 2021, 16:30:27 »
Depends whether you hadn't plugged it in securely, or squashed it somewhere. Not that either should have happened during a camcover change :-\
The plug is on the cable tray above the aux belt  tensioner
    • Grandland 1.5 diesel
« Reply #9 on: 31 December 2021, 17:38:52 »
There's always a chance the sensor could be fubared, one of mine failed.
Diesel till I die
« Reply #10 on: 31 December 2021, 19:24:02 »
True, but start with the obvious ;)
Omega Nige
  • Oxfordshire
« Reply #11 on: 04 January 2022, 14:18:27 »
Quick update, I un-plugged and re-plugged the knock sensor, bank 2 and moved the plug so it wasn't flapping about. Cleared the code and since then the light hasn't come back. Happy days  ;)
« Reply #12 on: 04 January 2022, 15:00:21 »
That makes no sense.
Bank 1 is UK driver side, which the code suggests.
Bank 2 is UK passenger side which would have been 0335.
In either case, the plug shouldn't be 'flapping loose' as they all have places to be restrained.  ???
« Reply #13 on: 04 January 2022, 15:06:24 »
The OP's code suggested Bank 2.
« Reply #14 on: 04 January 2022, 15:14:56 »
Coupled with 'behind the alternator'...
