Author Topic: Management light.  (Read 6884 times)
Re: Management light.
« Reply #15 on: 04 January 2022, 15:17:46 »
Coupled with 'behind the alternator'...
that depends on where you're standing!  ::) ::) ;) ;)
« Reply #16 on: 04 January 2022, 15:19:11 »
That makes no sense.
Bank 1 is UK driver side, which the code suggests.
Bank 2 is UK passenger side which would have been 0335.
In either case, the plug shouldn't be 'flapping loose' as they all have places to be restrained.  ???
The OP's code suggested Bank 2.
The OP's codes suggested Bank 2. P0330.
Whether or not the repair to the cable damaged by the aux belt is a good enough repair isn't relevant, because the code absolutely, 100% pointed to Bank 2 Knock sensor.  Sadly, the pedal trick doesn't give sub codes, so can't tell what it thought the issue was with Bank 2 knock sensor though.
