Author Topic: Bonnet auxiliary/emergency release mod?  (Read 4244 times)
rds
Re: Bonnet auxiliary/emergency release mod?
« Reply #15 on: 08 January 2022, 20:05:57 »
many thanks; it's always good to share tips!
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #16 on: 08 January 2022, 20:08:47 »
It's always worth checking that the pin and spring on the bonnet are in good condition, clean and lubricated as well as the mechanism on the crossmember :y
rds
« Reply #17 on: 08 January 2022, 20:18:27 »
good point Nick; I will see if the spring is compressible, however it is lubricated.
grifter
  • Paisley, Scotland
    • Omega 2.6 CD / Elite 3.2
« Reply #18 on: 08 January 2022, 21:08:06 »
Apart from general lubrication, how else can you determine if the spring is ok? I generally give them a bit of oil or spray grease every so often, same with door hinges and catches and anything else that moves/pivots is a hinge.
  • Chatham, Kent
« Reply #19 on: 08 January 2022, 21:56:40 »
Check that the spring isn't rusted to the retaining cap or broken, and that there isn't any crap caught in it.
The pin needs to be straight, reasonably clean, greased and burr free where it slots into the latch. They usually screw in or out to provide the bonnet closed height adjustment, so if the car has been damaged at the grill/headlight height that might be necessary.
It only takes minor faults with any of these to make the whole assembly reluctant to release.
rds
« Reply #20 on: 08 January 2022, 23:09:20 »
I will thanks - do you think the couple of heavy slams of the bonnet might have mal-adjusted the alignment?
« Reply #21 on: 09 January 2022, 00:12:19 »
Almost impossible to say either way. If one or both of the bump stops are missing, then the extra twist won't help. If the pin is misaligned then the extra force may have bent it... Any corrosion may cause binding, and may not be immediately visible.
rds
« Reply #22 on: 09 January 2022, 00:15:10 »
nothing missing thankfully but a clean up wont go amiss anyway.
grifter
  • Paisley, Scotland
« Reply #23 on: 09 January 2022, 12:30:23 »
Funnily enough there is a roundish dent on the front of the slam panel, just left of the catch area it's been there since I had it so don't know what caused it, and if it's caused any mis-alignment issue. Will give the spring and pin a closer inspection as well see how they look.
« Reply #24 on: 09 January 2022, 12:47:30 »
Almost certainly pushed back then. How much depends on the original impact.
The fact you have to force the bonnet, however slightly confirms that things are out of whack.
grifter
  • Paisley, Scotland
« Reply #25 on: 09 January 2022, 19:00:51 »
Certainly sounds plausible, given the elite has no issues with bonnet and CD has even after fine adjustments and lubricating everything. Maybe do a couple of measurements between the cars see if anything different.
« Reply #26 on: 10 January 2022, 13:16:10 »
The upper cross member is three spot welds onto the inboard top lip of the chassis rail, six as an end cap to the inner wing top structure and 11 more to the edge of the inner wing panel below the headlight aperture. Doesn't take much to disturb it.
