Rear Brakes Question
Started by Lizzie Zoom, 19 January 2022, 12:22:29
Quote from: dave the builder on 19 January 2022, 15:48:23
Quote from: Andy B on 19 January 2022, 15:36:51
Quote from: dave the builder on 19 January 2022, 14:26:37.....
The "park brake/handbrake" is also the "emergency brake" in the event of rapid brake fluid loss .
selecting P at 100 err I mean 70 won't end well for the gearbox  :P
so why wear it out using it when you don't need to  ::) ::)
Using it stops the cable (which is plastic lined) and mechanisms from seizing .
Also , in the event of someone crashing into the Omega while it's parked (which has happened to me many times  >:( ) it puts less strain on the park pawl
Failure of the pawl could see 2 ton of Vauxhall's finest opel rust on it's merry way down the road
Dave, You have realised that I'm not being serious ...  ::)
Quote from: Doctor Gollum on 19 January 2022, 15:42:12.....
BMW and Mercedes have both been long term users of rear discs with the parking brake being contained within the hub drum of the disc brake. The Omega is no different in this regard. ....
Though my 07 R Class used a disc/drum set up using a foot operated parking/emergency brake, my ML now uses an electric parking brake that operates on the disc.
Quote from: Andy B on 19 January 2022, 17:38:41
The pedal operation is a variation on the traditional hand operated lever or the old umbrella handle type. The pedal operated mechanism is adjusted in exactly the same way as the hand lever... The ratchet/pawl has a fixed range of motion and the cable connecting the lever to the rear cables is adjusted for length as (very rarely) required. The release handle is a cable or chain (on some '70s models) that is basically an elaborate version of the push button on a traditional handbrake lever.
Switching to electric is probably as much to do with cost to manufacture as much as anything else.
Lizzie Zoom
Thanks for all the feedback on my question :y :y
Now I have to ask;  is the, rather antiquated, system any different on the new electric vehicles?
To me, apart from brake cables for the main drums being replaced by hydraulic pipes to brake pads, but still cables being used for hand brakes, with fail safe systems, nothing has really changed since my A40 days.
I know if a engineering system is found to be good the designers stick to it, but what will or can change in the future?
(I am in a questioning mood trying to get my mind off something else..................!!) :P
dave the builder
Quote from: Andy B on 19 January 2022, 17:35:38
But someone else could read this thread  :o
it's on the internet  :D
Quote from: Lizzie Zoom on 19 January 2022, 17:54:57
New vehicles use a switch, some cables, an ECU, with at least one electric motor and linkage to do the same job. They're shit. You need to edit your post, and replace antiquated with efficient.
Quote from: Doctor Gollum on 19 January 2022, 17:47:14
I know how they work .... my point was that even MB seem to be moving away from a top hat disc/drum set up in favour of a parking brake that operates on the disc - as you say being cheaper
electric hand/parking/emergency brakes seem to be the norm these days  ..... presumably cheaper.
Two people I know of that have recently passed their driving test had no idea whatsoever how to do a hill start in their now older cars because they'd learned & passed their test in a car with an auto handbrake or with HOLD assist of some sort.
Lizzie Zoom
Quote from: Nick W on 19 January 2022, 18:12:54
In other words it does it's job and has proved the test of time :D ;)
My daughters Grandland X has one of those electric 'hand' brake with a little button to turn it on when stopped.  It always intrigues me that I  can dis-engage the brakes by just driving against them after being stopped in traffic ;)
Right upto the point where you can no longer do that...
Quote from: Lizzie Zoom on 19 January 2022, 18:26:20
I like the BMW (and probably other manufacturers as well) setup that applies park automatically if you open the drivers door while stationary with the Car in D or R..... I can only guess that was developed for our friends over the pond  ;D
Quote from: Lizzie Zoom on 19 January 2022, 18:26:20....
but the throttle is being pressed too to make it disengage
Quote from: VXL V6 on 19 January 2022, 18:29:58...
My ML does this too .... though the R Class before it didn't  :-\
Lizzie Zoom
Yes, like the chiming sound when the doors are open, which I rather like when I have been in the States. :D ;)
