Author Topic: Honda CR-V 2.2 cdti v-tec 07 ish  (Read 13354 times)
Re: Honda CR-V 2.2 cdti v-tec 07 ish
« Reply #15 on: 18 February 2022, 13:05:52 »
The other consideration with some XC90s and most CRVs is that they are wwd not awd*, so not so great for towing.
* I know the R280Cdi is only two wheel drive, but at least it is the back wheels.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #16 on: 18 February 2022, 19:13:36 »
All XC90's are permanent 4x4 :y
other rides
« Reply #17 on: 18 February 2022, 19:38:01 »
Not quite true...
https://en.wikipedia.org/wiki/Volvo_XC90 ;)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #18 on: 18 February 2022, 21:20:29 »
CR-V's normally drive via the front wheels with the rear wheels kicking in via a electronic clutch which is activated when the front ABS sensors detect front wheel slip.
Similar system on most VAG cars (4motion ect)
No manual override
« Last Edit: 18 February 2022, 21:28:34 by tigers_gonads »
« Reply #19 on: 18 February 2022, 22:18:03 »
That's assuming that it's actually got a rear diff ;) Wwd CRVs look identical to the awd models. Same with the Volvo XCs ;)
At least the Mercedes 4matic system, whilst automatic, is rear wheel drive when in 2wd mode. (on the models that are tradionally rear wheel drive as opposed to the Clit based A Class derivitives.
« Last Edit: 18 February 2022, 22:20:58 by Doctor Gollum »
henryd
  • west cornwall
« Reply #20 on: 19 February 2022, 13:44:51 »
Not quite true...
Must be bloody rare then as I have never seen one on the originals ,current generation does do wrong wheel drive on some models
other rides
« Reply #21 on: 19 February 2022, 14:18:09 »
Base model 2.4s for the most part. D3s and Drive E on the slightly newer ones...
The Phase 1 and its facelifts ran from 2002 - 2014ish iirc.
« Reply #22 on: 22 February 2022, 08:22:55 »
Not quite true...
Yep plenty of front wheel drive ones about (transverse engine setup and Aisin box), haldex based AWD so need to watch the front/rear tyre tread deltas or it takes the Haldex clytch plates out,
« Last Edit: 22 February 2022, 08:27:14 by Marks DTM Calib »
