Droning Noise
Started by Sir Tigger KC, 14 March 2022, 10:43:02
Quote from: TheBoy on 14 March 2022, 15:06:03
Presumably wheels are same size all round, so a simple back to front swap will confirm if its tyres (I know how you like your cheap as chips, black and round tyres).
Done that.  :y  See OP!  :D
Oh and the tyres might be cheap, black and round (Runway Performance 926), but they appear to be OK.  :y
Quote from: Sir Tigger QC on 14 March 2022, 15:36:36
Ah, my bad, I misread in that you'd swapped the rears with each other, but still heard noise from back ;D
Can't be much else really, either brake (road or handbrake) is/was binding, or the bearing is noisy (possibly due to a brake binding), or there is sufficient play for the wheel/disc to rub.
Either way, need to jack it up, and have a fondle :y
If one of the rear tyres was out of round, or misshapen in some other way, changing around the rears wouldn't make any difference. You need to fart around much more than that  ;D
Edit: sorry I guess you meant you did front to rear. My bad  :P
Diesel till I die
Have you ever thought of getting someone who knows what they're talking about to take a look?  ;D
Diesel till I die
Viral_Jim
Nah, its much better to stick a post on a forum full of moaning old codgers, asking them to guess the source of a noise they cannot hear on a car they've never seen.  :y
Quote from: Viral_Jim on 14 March 2022, 16:21:06
It's diagnostics, Jim, but not as we know it  ;D
Diesel till I die
Quote from: Sir Tigger QC on 14 March 2022, 13:37:43
Quote from: Andy B on 14 March 2022, 13:36:22
Input bearing to the diff?
FWD.  ;)  :y
Ooops! Maybe I should have read from further up thread  ::)
Quote from: STEMO on 14 March 2022, 15:54:58
It's booked in next Tuesday.  :)
Fraggles Rock
Quote from: Sir Tigger QC on 14 March 2022, 17:30:58
Pass or fail, they will tell you either way...
If the repair plus labour is worth more than the value of the car (In your case, say, £300) I know of a very good astra derv auto that you can buy at a very reasonable price.
Of course, 'reasonable' might be subjective.  ;D
Diesel till I die
Rangie
Just turn the volume up on the radio this may help..
Quote from: STEMO on 14 March 2022, 17:45:32
Time for a change, old lad? :)
ronnyd
That's the last thing anyone on here considers Steve.  :D
You forget that I have a spare car!  :y
Which is also fooked!  :-\  ;D
There is more general car knowledge on here than you will find in most garages, modern mechanics are rather hopeless
