Matrix hose leak.
Started by Migv6 le Frog Fan, 22 March 2022, 11:53:54
Migv6 le Frog Fan
Thanks for the ideas. Going out to have another go at it now.  :y
Migv6 le Frog Fan
found a coolant hose in my stash that was a similar shape and length to the troublesome one.
Fitted it with a jubilee clip at each end and all seems well now. :)
amba
Fingers crossed the ship is now water tight :y
LC0112G
Quote from: Nick W on 23 March 2022, 11:34:42
Quote from: LC0112G on 23 March 2022, 11:20:25
Quote from: Migv6 le Frog Fan on 22 March 2022, 20:15:34
Considered that but the matrix pipe is around 12mm diameter and the rubber pipe without the locking connector is quite a bit bigger.
Its fixed with a clamp at the other end to something the same size, so would need some kind of reducer before it reaches the matrix pipe.
I hacksawed the two plastic quick release clamps off, and then just pushed the rubber hoses onto the heater matrix pipes and secured them in place with jubilee clips. I even swapped them round on occasions to try and flush out the heather matrix by reversing the flow. So it should be possible without reducers.
You replaced a perfectly engineered custom hose fitting with a jubilee clip on an Omega? Don't you know that will make every other Omega hose in the world leak out of sympathy? Or osmosis, supercalifragilisticexpialidocious or other misapplied jargon.
One of the hoses blew off on the M3 at silly o'clock in the morning on my way home from Gatwick. Managed to coast into Fleet services, bodge it back together, re-fill with tap water, and get home. Further investigation revealed the locking fingers had bent and one had broken off. Ordered a new hose, but needed to use the car in the mean time, so hack saw and jubilee clamps whilst that arrived. New hose is still on the shelf in the garage, and the jubilee clip has held for perhaps 5 years :D
Never had real problems with jubilee clips. Those wretched spring clamps though  >:(
Quote from: LC0112G on 23 March 2022, 13:51:48
Yes, I agree hence the sarcasm.
I rarely refit spring clamps, and never on my own cars.
