Starting problem 3.0 v6
Started by danzigfan, 24 March 2022, 09:13:28
dave the builder
that would do it
fuel is too lazy to travel all the way to the rail if there's a hole nearer  :P
my in tank rubber fuel hose had started to deteriorate .
it's NLS and shaped (so not easy to replace with standard hose)
i replaced with a PROTEC CONVOLUTED NYLON IN-TANK FUEL HOSE clicky
14503   Convoluted In-Tank Fuel Hose, 280mm Length, 8mm & 9.5mm ID
Available from Deamon-tweeks
https://www.ebay.co.uk/itm/311899165989
danzigfan
Nice to know it can be replaced because I found cracks on both bigger hoses inside the tank
dave the builder
Quote from: danzigfan on 07 April 2022, 18:05:04
If that's the case it might be wise to replace the delivery one (from the pump out) sooner rather than later  ;)
sudden power loss can put you in a dangerous situation  :-X
danzigfan
It's on to do list, thwnks.
Well car starts fine now, from first try
