V6 head removal
Started by Webby the Bear, 22 April 2022, 21:08:33
Webby the Bear
Lol thanks for all the advice but if I got a new car it wouldn't be an omega that would probably have a list of its own issues.
As for the need to remove the heads. My way of thinking is I want to change those lifters and getting the manifolds out for inspection is easier just to come off with the heads. Also there's a few bolt holes in the heads that need helicoiling so I'll get those done at same time. Whilst the head is off being tested I can get the other bits done. And then wallop. One or two weekends later shes back on the road. That's the plan anyway 😃
RIP Paul Lovejoy
GastronomicKleptomaniac
Ive taken a veritable smorgasbord of photos around my 3.2 while it was sat on the floor out of the car. PM me your number if you want them WhatApping over :y
BazaJT
The coolant bridge has what are called Dowty washers[from memory 4 of them two per bolt] the oil cooler pipes are held to the oil cooler by banjo bolts-again from memory it goes oil cooler,rubber "O" ring,cover plate,thin metal washer,nut,thin metal washer,oil cooler pipe,thin metal washer,banjo bolt.
Quote from: Migv6 le Frog Fan on 23 April 2022, 15:00:18
With that list of jobs I would be considering looking around for a good Omega that doesn't need all that work.
The only way of getting one that doesn't need the usual full suspension rebuild or a load of often delayed engine work is to find a car that recently had it done by someone who knows what they're doing and can prove both. Then you need to ensure that the car isn't hiding a lot of hard to fix rot. That all means that such cars are very hard to find. Fixing a car whose history you know is actually the simple, straightfoward, quick and cheapest option
Webby the Bear
Quote from: GastronomicKleptomaniac on 23 April 2022, 17:49:59
Thanks gk. pm now 😃
RIP Paul Lovejoy
Webby the Bear
Quote from: Nick W on 23 April 2022, 20:12:27
That's my idea mate. Just try n keep the old bus going.
I am going to do oil pressure test and compression checks too just before I start just to see if there's anything wrong elsewhere 👍
RIP Paul Lovejoy
Enceladus
Quote from: Webby the Bear on 22 April 2022, 21:08:33
Last question... can u remind me where u put that green snot? If memory serves it's just under the front cam caps but honestly can't remember 🤣
There's some photos in the guide here.
However don't use the GM "green snot". I know the green sealer is in Haynes and also TIS but it goes hard and then crystallises, which contributes to leaking. Instead use the black high temperature sealer for the oil pan, GM part 90485251. Actually it doesn't have to be black, there are other colours. Just that the GM Opel sealer is black and way over priced. Grey sealer was used in the guide photos
biggriffin
Quote from: Raeturbo on 23 April 2022, 16:03:20
Picture of 2003 Vauxhall Omega 3.2 v6 elite estate For Sale
£9,995
Vauxhall omega elite v6 automatic estate tourer!!!! the ultimate vauxhall tourer 10 stamp service history, 83,000 miles, 3 owners. exceptional condition throughout. just had full service, timing belt replacement, 4 new uniroyal rainsport 5 tyres, alloys refurbished, fully loaded, 3.2 v6 super smooth engine, automatic ...
83,500
6 Mar 2022
Private
                      Well some are fetching pretty good money😱
Weres the link, so we can look at it, then slag it off :y
Hoof'land storeman.
https://www.ebay.co.uk/itm/255504113631
This one?
Mileage is about ripe for ALL the Omega goodness :D
biggriffin
Quote from: Doctor Gollum on 24 April 2022, 10:14:45
This one?
Now if that's the one I think it is??
That came from Hoof'land was owned by a lovely old chap, who Gave yes gave it away to the guy who did all the servicing on the car,, I missed it because I was on holiday,, I offered a price on the car,  :'(
Hoof'land storeman.
Raeturbo
Laying a rubber road.
