Author Topic: Barn find starts but then stops  (Read 27847 times)
arjc1
  • Suffolk
    • 2003 Omega V6
Re: Barn find starts but then stops
« Reply #45 on: 22 June 2022, 23:10:07 »
Sorry - I should have been clearer - the EML came on before I unplugged the MAF after going for a bit of a drive to test the thing out on the road - but it has remained on obviously through removing the MAF and re-connecting it.
Yes - the pressure gauge has a flexible hose - I can try that. What's the betting this is just the fuel pump which is what many of you told me in the first place - but it looks a big of a dog to get out with the towbar strengthening in place!
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #46 on: 23 June 2022, 10:43:08 »
there is an access panel in the boot to get to the fuel pump
  • Auckland
    • Mazda MPV
« Reply #47 on: 23 June 2022, 11:12:30 »
which shouldn't be obstructed by the towbar bracketry.
The towbar I fitted certainly didn't go across the access panel.
« Reply #48 on: 23 June 2022, 11:41:47 »
The factory tow bars have a plate that bolts through the boot floor, but no telling what aftermarket bodgery has done.
The plate is only held by four screws, so undoing three should allow access as the plate can then be pivoted to one side ;)
arjc1
  • Suffolk
    • 2003 Omega V6
« Reply #49 on: 03 February 2023, 15:27:29 »
So - just to close this one out. The car has been sitting on our driveway for the past 6 months because life got in the way, but this week I've had a need to get it running again. This time I couldn't cajole it at all to keep running so, with no spare time available, I sent it to the local garage - along with a spare fuel pump to fit. 1.5 hours later they came back with it fixed - it was actually a split fuel hose inside the fuel tank - so the original pump was working fine, but most of the fuel was falling back into the tank!
Thanks for all your interest and support in getting this going.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #50 on: 03 February 2023, 16:55:12 »
Good, pity you didn’t take it earlier, but hindsight is a beautiful thing👍
Laying a rubber road.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #51 on: 03 February 2023, 17:55:47 »
I've had the exact same problem in the past  :(
regular fuel rated rubber line swells inside the tank
the solution is https://www.ebay.co.uk/itm/311899165989  ;)
Raeturbo
  • South Wales
« Reply #52 on: 03 February 2023, 19:27:44 »
Indeed and that’s why due care is needed with this E10 shit, I won’t put it in any of my cars
cam.in.head
  • Online Online
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #53 on: 04 February 2023, 09:11:05 »
neither will i if i can help it. esso synergy 99 in all mine .
im pretty sure gates r14 hose is suitable for submersion and the type dave mentioned too.
my other cars are all getting changed to codan r9 including the short injector ones on jetronic  injection cars.so at least e10 proof if im stuck.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #54 on: 04 February 2023, 12:16:31 »
The reason for the "Protec Fuel Systems Convoluted In Tank Fuel Hose - 8/9mm Ends / 280mm Long" in my link is because the original in tank hose is shaped with tight curves ,which is difficult to achieve with off the shelf hose in such a tight space  :y
grifter
  • Paisley, Scotland
    • Omega 2.6 CD / Elite 3.2
« Reply #55 on: 05 February 2023, 14:17:44 »
Hi Dave
Where does that fitment on the end of the pipe go or does that come off, is there a push on clip on the in tank pipe or is i tjubillee clips or those spring clips?
Had a look on the parts diagram and it doesn't show any type of clips I can see.
https://opel.catalogs-parts.com/#{client:1;page:part;lang:ru;category:car;catalog:v94;group:g;groupsub:0;subgroup:23-1}
« Last Edit: 05 February 2023, 14:20:25 by grifter »
cam.in.head
  • Online Online
  • West yorkshire
« Reply #56 on: 05 February 2023, 14:22:35 »
the last 'in tank' fuel hose i changed ,cant remember what it was on had some awkward bends in it.used copper pipe for the majority and just hoses to connect ends.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #57 on: 05 February 2023, 14:53:42 »
Hi Dave
The pipe doesn't come with the black plastic fitting shown on the ebay listing  ;)
both ends of the pipe have about 30mm of strait (NOT Convoluted) pipe ,1 x 9mm ID ,1 x 8mm ID
the rest of the pipe is convoluted /corrugated ,making it very flexible .
you need to gently heat (boiling water is OK, NOT a naked flame  >:D) the pipe to get it to slide on the pump and outlet .
standard fuel line clips to secure in place  :y
this pipe is a great "off the shelf solution "  ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
grifter
  • Paisley, Scotland
« Reply #59 on: 06 February 2023, 13:42:26 »
Hi Dave
Thanks, I've just got one as it will be a good piece of kit to have whenever I change that pipe, which I will do probably sooner rather than later.
G
Pages: 1 2 3 [4]  All   Go Up
