Amber indicator bulbs
Started by grifter, 01 May 2022, 15:12:49
grifter
Hi
Needing to replace the rear indicator bulbs as they're almost clear of the amber coating, is it just a standard amber indicator bulb I need, any specific code for them?
Thanks
G
cam.in.head
just a standard bau15s amber indicator bulb.(offset pins)i have found however that different makes seem to have a differing level of amber coating. ie some are more orange than others !
grifter
Quote from: cam.in.head on 01 May 2022, 16:01:16
Thanks, that's just the luck of the draw isn't it, how good a coating you get, hopefully they're better than the ones I got at the moment.
yellow or white is only really a problem at MOT time & I can't see most testers failing you .... just give advisory.
I've a box of amber bulbs in my garage ..... Ring IIRC
dave the builder
You can buy orange paint for bulbs  :)
Quote from: dave the builder on 01 May 2022, 21:53:35
Yes, but why would you?  ;D
Diesel till I die
Quote from: Andy B on 01 May 2022, 22:14:03
Quote from: STEMO on 01 May 2022, 22:08:10
exactly ....  ;D
The orange ones in my astra have been in there at least 8 years, so I don't think I'd save much money buying clear ones and a can of paint  ;D
Diesel till I die
dave the builder
Quote from: STEMO on 01 May 2022, 22:18:35
exactly ....  ;D
I re coat the old bulbs if required (my MOT tester is strict) and have plenty of spares from cars i've scrapped
the only bulbs I have to buy are HID ,LED ££ :o
Glad I made a few people smile  ;D
zirk
But then you have to buy the Clear Coat, the Wet and Dry, the Lacquer, Rubbing Down Compound, Paint Wipes, T Cut, Polish, Buffing Machine, and on and on, its just endless.
grifter
MOT up this week, thought they looked very white so decided to change them.
dave the builder
Quote from: zirk on 02 May 2022, 07:47:08
and that's all AFTER you've knocked the dents out of the glass and masked up the chrome work  :D
grifter
Now changed, and I'll rub off the remaining amber flakes on the old bulbs and keep those as spares, how's that for penny pinching!
