Author Topic: Headlight sensor plug - front - where does it emerge?  (Read 5034 times)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
As above... My careful placing of the loom as I was putting everything together means I've tucked the headlight level sensor out of the way. Where does it come out of the loom, so I stand a chance of finding it? :y
Re: Headlight sensor plug - front - where does it emerge?
« Reply #1 on: 14 July 2022, 14:19:38 »
As in the suspension sensors?  They all end up at a module in the OSF wheel arch liner.
« Reply #2 on: 14 July 2022, 14:24:56 »
Perfect, just what I needed, thank you! :y
« Reply #3 on: 14 July 2022, 15:10:46 »
Found it! Traced it through and found it tucked in a blitheringly stupid place behind the ABS pump. Because I am that good. Thanks again :y
« Reply #4 on: 14 July 2022, 21:20:56 »
Which makes sense as it runs with the abs sensor and pad sensor harness  :D
Page created in 0.031 seconds with 20 queries.
