Author Topic: Help! Help! Omega 2.2 petrol auto 2002  (Read 11776 times)
Steveh
  • Debyshire UK
    • Omega 2L 16V
Re: Help! Help! Omega 2.2 petrol auto 2002
« Reply #15 on: 06 August 2022, 17:47:34 »
If I remember right the mark on the crank pully should be about 4 o'clock theres a pointed marker that sticks out it should align with
When the camshafts are by their marks the crank mark is not pointing straight down as I think it is supposed to , it points to 4 o clock ( how do I upload pictures?)
addy
  • County Durham.  UK
    • 2.6 CD Saloon 2ltr omega
« Reply #16 on: 06 August 2022, 17:59:19 »
The mark on the pulley, lines up with a cutout at the bottom of the crank shield.
You can just see it on here. It is a notch. The crank mark is about the same size, in width. On the picture I have just timed the engine up. And have fitted the locking tool into the cam sprockets.
Drives 1995 2.0ltr CD Estate.  2002 2.6 CD saloon
addy
  • County Durham.  UK
« Reply #17 on: 06 August 2022, 18:02:26 »
This is the mark, that can be seen with the crank pulley still on. To do the timing belt, the pulley has to come off.
Steveh
  • Debyshire UK
    • Omega 2L 16V
« Reply #18 on: 06 August 2022, 18:04:02 »
Just checked the mark on the actual cam belt pulley should be straight down as addy posted but there's another mark on the aux belt pulley that should line up with the pointer.
addy
  • County Durham.  UK
« Reply #19 on: 07 August 2022, 10:14:56 »
Hi Veralum
For uploading pictures to here and other boards. I use this site, https://postimages.org/ it is free and you can drag and drop pictures. I set the image size to message boards, via the do not resize image option.  Once you have uploaded your photo, click on it. Then press the SHARE button , it will open a load of different links. The one you want is the direct link option. Press the button next to it that looks like a clipboard, this will copy the link. On the OOF forum, when you write your message. And want to add a photo, you select the button (it looks like a picture, below the Capital B button on the left. Then paste the link of your photo in between the img and /img. You can check if photo has loaded by doing a preview first.
Hope this helps.
« Last Edit: 07 August 2022, 10:21:39 by addy »
veralum
« Reply #20 on: 19 November 2022, 19:15:45 »
I rebuilt the head and all is fine, car runs great and passed its mot
« Reply #21 on: 19 November 2022, 19:29:23 »
 :y :y A result  :)
« Reply #22 on: 21 November 2022, 10:00:42 »
