Author Topic: Power steering hose - lower reservoir.  (Read 3214 times)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« on: 30 July 2022, 15:25:25 »
Naturally Ezekiel couldn't be happy with an MOT pass and decided to make a show of himself on my mother's drive.
I've found a PAS fluid leak from the hose connecting to the lower pipe on the reservoir - the one bit of pipe I didnt examine and it has partially perished.
My brain says if I chop the metal pipe a bit further down then I can fit an olive and compression fitting, onto a hose to replace the perished bit. If I do this will it simply explode and launch the fitting into a low orbit... Or is the pressure low enough thatthat will be fine?
When I had it all apart I took it to the local hydraulic hose specialist who looked at me like I'd brought him something from another planet... So that's out
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Power steering hose - lower reservoir.
« Reply #1 on: 30 July 2022, 15:28:12 »
Even the high pressure side is within the clamping of a Jubilee clip.
So you need some oil resistant hose the same bore as the pipe diameter, and a couple of clips.
Easy :y
« Reply #2 on: 30 July 2022, 16:18:37 »
Easy :y
Just what I wanted to hear! Thanks mate :y
