Author Topic: Key fob  (Read 2823 times)
tooleater
  • Rickmansworth,  Herts
    • Go faster Black MV6 Man
Key fob
« on: 06 August 2022, 10:53:03 »
Morning Guys,
can anyone let me know if Martin Imber, still rebuilds key fobs as mine is looking looking my rear arches  :-[ failing that are there any other key fob surgeons they could recommend.
cheers...
    • Grandland 1.5 diesel
Re: Key fob
« Reply #1 on: 06 August 2022, 11:44:36 »
Diesel till I die
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Key fob
« Reply #2 on: 06 August 2022, 12:31:00 »
Martin did some key fobs for me recently  :)
tooleater
Re: Key fob
« Reply #3 on: 06 August 2022, 13:16:58 »
cheers Dave  :y
Now for the M.o.t  ;)
tooleater
Re: Key fob
« Reply #4 on: 06 August 2022, 13:21:00 »
http://www.imber.me.uk/keyfob.htm
Cheers Stemo, thanks for the info. mot next week, but Im gonna let Mr Serek deal with it..
tooleater
Re: Key fob
« Reply #6 on: 07 August 2022, 10:31:33 »
3 button fobs are easy to repair, though the replacement rubbers from Ching Chong Chinaland can be a bit hard, if yours is in a bad way.
Switches are large enough surface mount that they can be done with a standard iron with a fine tip.
Battery holder - if this has come away, my standard repair method is to remove it completely, and repair the broken leg by soldering a piece off the end of a resistor etc to what's left to make a new leg.  Solder this back to the board, and I usually add a bit of glue between the battery holder and the PCB to give it more mechanical strength.
Top case rubbers, if they are trashed, no option but to replace the top half of the case.
HTH
