Author Topic: I need a new drill.  (Read 3909 times)
I need a new drill.
« on: 12 August 2022, 18:52:25 »
What are the advantages ( if any) of an 18V....20V....or 21V cordless drill over the elderly 12V Makita I currently use?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: I need a new drill.
« Reply #1 on: 12 August 2022, 19:45:55 »
If you're "drilling" then use a 240 volt one
If you're "screwing" then you won't be worried about D I Y  :D
redelitev6
« Reply #2 on: 12 August 2022, 21:39:37 »
 use an 18v Makita , good all rounder , give the screwfix site a look
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 12 August 2022, 22:19:30 »
18 and 20v are the same, just the bigger number is for Americans ::)
The advantage over what you have is more power and better battery life in a smaller, lighter tool. They might have a brushless motor to increase those advantages.
And your elderly Makita probably has Nicad batteries instead of the more suitable Lithium ones.
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #4 on: 13 August 2022, 06:47:11 »
All my 18v stuff is Makita and it's been excellent, the vast majority of what they sell is also brushless.
I've had one failure - cordless 18v circular saw packed up after being used on about 50 oak sleepers. The warranty meant makita picked it up, repaired it in about 3 working days and shipped it back all FOC.
The other stuff has been great and I use it way more than most DIYers.  :y
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
« Reply #5 on: 13 August 2022, 09:56:26 »
Indeed, and a must if drilling into concrete with a suitable bit, with hammer ability.  With really tough, reinforced concrete, a Kango drill is the baby to use as I have found out in my ‘concrete everywhere’ flat! :D ;)
« Reply #6 on: 13 August 2022, 20:39:46 »
Be aware of the Shitfix ones, they tend to be a lower cost, lower quality version of the ones other outlets sell.  Whether or not that's an issue depends on what you plan to use it for :)
« Reply #7 on: 15 August 2022, 14:13:01 »
I moved over to Dewat after the Makitas (mainly due to having a couple of batteries 'lying around'), had no issues and drills anything i need it to.
Just be aware that most of these brands have the cheaper entry level/DIY versions, and the better pro ones for a few quid more.
« Reply #8 on: 15 August 2022, 14:28:09 »
we've a load of 18v Milwaukee battery stuff at work. I've been pretty impressed with them all.
But I've not been paying  ;)
« Reply #9 on: 15 August 2022, 14:38:38 »
My Makita cost bout £100 in a sale at B&Q and I've never been that impressed with it.  :-\
The batteries were shagged after a couple of years and then the gearbox packed up just after the warranty expired.
I emailed them and they said Send it in.  They sent it back with a new gearbox, but said there was nothing wrong with the batteries.
So not bad really, and I replaced the batteries with cheapo's from Ebay which have lasted longer than the originals...  :-\
« Reply #10 on: 15 August 2022, 17:09:55 »
Your neighbours must love you.
Hammer drill in a flat will shake their fillings loose. :D
« Reply #11 on: 15 August 2022, 17:15:15 »
Not to mention the fact that the concrete is what holds the building up :-X
Lizzie Zoom
  • South
« Reply #12 on: 15 August 2022, 17:42:14 »
The neighbours are as bad as me ;D ;D
I have two below me and above who are renovating their flats, so drilling sounds are very common ::) ::) :D ;)
Lizzie Zoom
  • South
« Reply #13 on: 15 August 2022, 17:45:16 »
When I am putting up batons for new curtain tracks, or extending my ring mains for new sockets, I have no choice. As for the concrete ceilings that are faced with plaster, extending any lighting is a real pain.
Thank goodness though I have now completed all my renovations before I am past it! ;)
« Reply #14 on: 15 August 2022, 19:44:22 »
You need a man about the house, Lizzie.
Skruntie has always had a yen for you and I believe he is still a bachelor.
Wedding bells? :)
