Author Topic: Indicator stalk  (Read 3444 times)
Migalot
  • London
    • Omega 2.6 2002
Indicator stalk
« on: 27 August 2022, 19:30:15 »
A couple of years back, I bought a new indicator stalk (from eBay, IIRC) as my existing one showing signs of wear (decals worn off and gone shiny). I decided to fit it today. Dead easy job, but then I found that the self-cancelling function doesn't work. I refitted it, but it still doesn't work. >:(
Which is more likely? A faulty new item or I bu**ered something on first fitting. I'll refit the old one tomorrow, but just wondered if anyone else has experienced this?
Re: Indicator stalk
« Reply #1 on: 27 August 2022, 23:34:55 »
It's possible that you fitted the new stalk with the switch up or down, but it should sort itself out with a turn of the wheel :-\
Duff switch sounds most likely.
Migalot
  • London
    • Omega 2.6 2002
Re: Indicator stalk
« Reply #2 on: 28 August 2022, 16:24:48 »
Spot on DG!  :y :'(
Tried one more time with new one, but no dice. Refitted old one and it works fine.
