Author Topic: electric hand brake  (Read 4284 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
electric hand brake
« on: 31 August 2022, 22:58:00 »
whenever I switch power off the handbrake applies itself & on start up procedure is start engine press hard on brake pedal to disengage handbrake, Does anyone  know what i need to do in regards releasing handbrake when i have to change rear discs or pads
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: electric hand brake
« Reply #1 on: 31 August 2022, 23:08:27 »
Normally rear pad replacement with electric handbrake is via diagnostics to retract caliper
other rides
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #2 on: 31 August 2022, 23:24:08 »
Ludicrous over complication in the name of progress for its own sake.  ::)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 31 August 2022, 23:35:41 »
Solving a problem that nobody had, but added a number that make things worse
« Reply #4 on: 31 August 2022, 23:46:08 »
My Merc has an option in the dash cluster to change rear pads ..... anything similar on yours?  :-\
« Reply #5 on: 01 September 2022, 08:05:48 »
Most cars have a button press sequence to put the rear callipers into service mode or in one of the menus
« Reply #6 on: 01 September 2022, 08:16:09 »
And utterly useless for 1 point u-turns in the road.
(though I'd argue any disc handbrake is)
    • 530D M Sport, 330i Coupe
« Reply #7 on: 01 September 2022, 10:27:12 »
I do like the auto hold feature when driving in traffic, also holding the car on the rear brakes is far more preferable than the fronts if the discs are hot.
« Reply #8 on: 01 September 2022, 13:52:55 »
'HOLD' on .my Merc uses the normal brakes  .... a double shove on the pedal engages it
« Reply #9 on: 01 September 2022, 14:14:53 »
I think mine has the hold function as it is a PITA to get it moving again.
Traditional foot operated parking brake though. Thank goodness ;D
« Reply #10 on: 01 September 2022, 17:34:06 »
Either press the loud pedal or give the brake pedal another shove  ;)
I rarely used it .... my MOT tester used it more than me  ::)
« Reply #11 on: 02 September 2022, 07:36:30 »
Hold is a function of the ABS module via the usual road brakes, it doesn't use the park brake (as to slow to release)  :y
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #12 on: 02 September 2022, 09:24:48 »
Is that the same on VW’s. I am sure I can hear rear mechanically release on my. Golf.
I like auto hold but hate electric handbrakes. You cant open your  door without the handbbrake coming on and so on. Too many interlocks. Mine went faulty and needed a new swith( which they had in stock……) 175 euros. IT is clearly exposed to the dust and dirt. Poor design hence despite selling very few DSG in Spain, the small dealer had one in stocck!
« Reply #13 on: 02 September 2022, 11:26:34 »
Certainly on later JLR products thats the case.  Don't think it is on many other marques that Enterprise give me...  ...on the rare occasions that they can actually be bothered to give me a car ;D
