Author Topic: Black sealant 90485251 equivalent  (Read 18756 times)
    • Grandland 1.5 diesel
Re: Black sealant 90485251 equivalent
« Reply #15 on: 04 October 2022, 06:37:52 »
Both out of stock.
Diesel till I die
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #16 on: 04 October 2022, 08:26:57 »
That's a problem these days. You may be able to find what you want, but whether it's actually in stock is another matter.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #18 on: 04 October 2022, 10:18:50 »
If only it was as simple as ringing any factor and asking for a tube of oil-resistant sealant for sumps.
Oh wait, it is that simple.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #19 on: 04 October 2022, 11:00:57 »
 Are you suggesting using a non approved, non genuine part... You should know better. ;D
Hoof'land storeman.
  • Chatham, Kent
« Reply #20 on: 04 October 2022, 11:34:09 »
Yes, it will result in old testament wrath of God, fire and brimstone coming down from the skies, rivers and seas boiling, human sacrifice, dogs and cats living together, and mass hysteria. But it will be worth all that, because at least the oppsing cam covers won't leak.
biggriffin
« Reply #21 on: 04 October 2022, 14:41:42 »
 Precisely... I won't say what I use, but its useful around the house, and comes in various colours, and can be used for exhausts, cam covers, water pumps, etc.
Hoof'land storeman.
« Reply #22 on: 04 October 2022, 15:24:53 »
It won't for sealent, the original stuff was a loctite product and was a simple oil tollerant silicon sealent.
The oil cooler plate sealent was a bit more special, but still a loctite product
Enceladus
  • London
« Reply #23 on: 05 October 2022, 12:17:04 »
Can the oil cooler sealer be used on the cam cover seals in lieu of the sump sealant?
« Reply #24 on: 05 October 2022, 12:59:36 »
If you're a VX dealer you might have an official answer to that, but don't see why it couldn't be, after all we're only talking about 4 1/4" blobs of it...
  • Chatham, Kent
« Reply #25 on: 05 October 2022, 13:07:57 »
Probably.
But the cam covers are notorious for leaking and replacing the gaskets isn't a five minute job, so using the specified(or equivalent) sealant to improve the odds of a proper job is sensible.
« Reply #26 on: 05 October 2022, 13:24:01 »
Probably.
Equally, they're a service item because of their known failure rate.
Changing them every 3 or 4 years would be more effective than worrying about the sealant type.
This also applies to anything with a BMW badge.
