Pages: 1 2 [3]  All   Go Down
Author Topic: New tyres for the Disco  (Read 13134 times)
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: New tyres for the Disco
« Reply #30 on: 30 October 2022, 11:58:27 »
ronnyd, if you regularly cross over the Orwell (and clearly you do being able to point out the landmarks), can you just count you only have 5 fingers per hand?
Only 4, the other digit is called a thumb.  :P  ;)
« Reply #31 on: 30 October 2022, 12:02:52 »
That will change if you keep going to far east....
ronnyd
« Reply #32 on: 30 October 2022, 12:07:13 »
Any further and i could end up with slanty eyes.  ;D
« Reply #33 on: 31 October 2022, 07:33:23 »
Does the FType still use the Ford V6? :D
It never was an engine Ford used
It was a design JLR did massive development on to create the blown V8 and then they dropped two cylinders (block is the same length and angle) to create the V6
« Reply #34 on: 31 October 2022, 08:07:13 »
Didn't stop them casting it with FoMoCo all over it...  :D
Not looking for a fight about it, just that I find it an amusing sidenote.
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #35 on: 31 October 2022, 13:27:16 »
I thought the FoMoCo one was used in the s-type, x-type & XJ (plus about 12 early XFs) up until about 2009, same one that Aston welded together in pairs to make the V12 for the DB9 et al (not actually welded, before anyone gets smart  ;)).
« Reply #36 on: 31 October 2022, 21:09:08 »
https://youtu.be/z97PBTyvmZ0
Was the video series that raised the tongue in cheek observation  ;)
« Reply #37 on: 02 November 2022, 08:26:24 »
V6 and V8 engines were assembled at Fords Bridgend plant until a few years ago.
Consequently all castings had FoMoCo on them as that was the production origin (not the design)
« Reply #38 on: 02 November 2022, 16:04:03 »
I used to run my 5.0 SC XFR with the crappy plastic engine cover removed. It looked better. Sold it on Ebay for around £150 with the front splitters which I also removed because they were too easy to scrape. :-X
Pages: 1 2 [3]  All   Go Up
