Author Topic: Shock went into the boot  (Read 14614 times)
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
« on: 27 November 2022, 18:38:39 »
Hi guys...iz there a part available to fix this rust issue? Anything at all?
danzigfan
Re: Shock went into the boot
« Reply #1 on: 27 November 2022, 18:50:57 »
Omega has new rear panels, new rocker panels, is completely sorted and was repainted this spring. I didin't even think it would rust trough where the shock is.
I don't want to scrap it
« Reply #2 on: 27 November 2022, 19:55:54 »
The shock turret can theoretically be replaced by drilling the spot welds and welding in a replacement turret removed from a rust free inner quarter.
I had an at length debate on here with Terry Paget on the very subject.
Obviously there will be those that insist that it can't be done.
danzigfan
« Reply #3 on: 27 November 2022, 19:57:42 »
The difficult part is finding rust free inner quarter....thanks
« Reply #4 on: 27 November 2022, 19:58:24 »
The actual turret panel is about 6" square and if you remove the rear wheel arch liner or boot trim, you can clearly see it.
In theory it would have been available as a separate piece.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #5 on: 27 November 2022, 19:59:26 »
A good welder will replace that section with an available part
probably won't be a "rust free" omega panel though  ;D
danzigfan
« Reply #6 on: 27 November 2022, 20:03:10 »
Thanks....I'll take her to welder tomorrow, to see if it can be done and the price of it.
« Reply #7 on: 27 November 2022, 20:06:40 »
90566605
90566606
Are the part numbers for the inner quarter assemblies.
« Reply #8 on: 27 November 2022, 20:07:25 »
Pull the boot carpet before hand so they have a clear picture as soon as they open the boot.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #9 on: 27 November 2022, 20:11:05 »
something like this example clcicky , welded in ,just a case of finding something that fits ,big enough to replace the section of rot .
danzigfan
« Reply #10 on: 27 November 2022, 21:17:53 »
Thank you all, will report tomorrow
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #11 on: 27 November 2022, 21:38:10 »
Had this on our sedan. Left shock went through the turret. Cut a turret out of a car at the scrap yard and got someone to weld it in. Couple of years later same thing happened to the right shock. Just by coincidense it happened on the way to the Opel dealer for some programming. Dealer welded it back up the same day. Several years ago and car is still in daily use. Wasnt that expensive either.
« Reply #12 on: 28 November 2022, 10:02:40 »
I can't see that working due to the shape of the affected area.
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #13 on: 28 November 2022, 15:32:53 »
that actual unit may be of use if cut down and used as the mounting bit only .depending on how far the rust has extended.
otherwise an easy enough area to fix with (as mentioned) an omega section or a suitable alternative. its only a rounded section after all.
« Reply #14 on: 28 November 2022, 21:46:40 »
It would make a decent mould for a prosthetic arm. The surface the shock mounts against isn't actually flat ;)
