Author Topic: fault codes  (Read 4516 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
fault codes
« on: 27 November 2022, 20:57:07 »
does anybody on this forum have any idea where i can get a list of fault codes & the meaning of them for a DS ds 4 . I have tried the french car forums both citreon & ds without luck,  my eml is on & urea warning appeared momentarily, topped it up & it took 15ltrs to fill the tank. initially eml disappeared but has returned.  i will have a look tomorrow & delete any codes, but it would be handy to know if any codes appear what they mean,  :y
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: fault codes
« Reply #1 on: 27 November 2022, 21:52:42 »
Assuming that you have a code reader, does it not have a DTC ‘Look Up’ function, so that if a fault code is present/active you can look it up on the code reader.  :-\
raywilb
    • Citroen C4 Cactus
Re: fault codes
« Reply #2 on: 27 November 2022, 22:07:52 »
cannot look it up until tomorrow . omitted to say on original post , the car running as it should.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: fault codes
« Reply #3 on: 28 November 2022, 09:38:15 »
Google is your friend Ray, itll normally de-cypher any code for you
other rides
Re: fault codes
« Reply #4 on: 28 November 2022, 13:04:47 »
Emissions codes are regulated and have to be standardised, so google should provide the answer.
raywilb
    • Citroen C4 Cactus
Re: fault codes
« Reply #5 on: 29 November 2022, 18:50:41 »
[/quote  will give it a go the DS  forum is not a patch on oof. getting UO29D & P200
    • Grandland 1.5 diesel
Re: fault codes
« Reply #6 on: 29 November 2022, 19:28:26 »
Diesel till I die
Re: fault codes
« Reply #7 on: 30 November 2022, 01:31:33 »
Could that be as simple as needing a DEF refill :-\
Re: fault codes
« Reply #8 on: 30 November 2022, 07:55:44 »
Comms fail suggests either the AdBlue ECU is lacking power or has an issue (be it wiring or the ECU itself), so start  by checking wiring and fuses
Re: fault codes
« Reply #9 on: 30 November 2022, 08:33:31 »
I should add that all codes should have a suffix which is missing from yours, that would tell us more  :y
raywilb
    • Citroen C4 Cactus
Re: fault codes
« Reply #10 on: 30 November 2022, 21:16:16 »
Update -  i  cleared both codes & both disappeared for 2 days , UO29D has come back & that reads as  -
  fault in communication with De NOX system , so will have to check that out,  ( not sure where to start looking tho )
