Author Topic: cylinder head  (Read 12858 times)
countrywoman
  • worcestershire
    • skoda yeti
cylinder head
« on: 03 December 2022, 16:27:42 »
After getting the head I bought refaced I went to fit it (x30xe) and found the deck height to intake was a lot bigger than the old heads. Ended up robbing the intake valve out to go in the old head. Now this engine is ex plod so would it have been modified to a higher compression? If it has had them both refaced then they took loads off or is there a low compression version
Re: cylinder head
« Reply #1 on: 03 December 2022, 19:04:15 »
It's not the correct head for that block.
There are differences between the four V6 head options.
« Last Edit: 03 December 2022, 19:05:56 by Doctor Gollum »
Re: cylinder head
« Reply #2 on: 03 December 2022, 19:17:38 »
You could fit the heads from a 3.0/3.2 to a 2.5/2.6 respectively to give better breathing under load, but only if you fitted a pair of heads and the matching breather bridge as they aren't interchangeable.
Either your engine isn't a 3.0 or your new head is wrong.
Electrically, the 2.5/3.0 are identical, as are the 2.6/3.2 and yours wouldn't be the first Omega with a replacement engine that was misrepresented by the seller... Especially as the 2.5 is architecturally related to the C25XE. There were more Vectra 2.5s than 3.0 Omegas.
countrywoman
  • worcestershire
    • skoda yeti
Re: cylinder head
« Reply #3 on: 03 December 2022, 21:16:37 »
It looks identical just has more meat on the face by a good mm, not bothered at least the valves fit. Now just need 2 guides replacing in the other head.
Re: cylinder head
« Reply #4 on: 04 December 2022, 00:25:21 »
They might look the same at a glance, but that you can see the difference on the head tells you it isn't right :-X
You will be bothered when the inlet divider breaks as you tighten it down and/or doesn't seal.
Shame to do all that work only to bodge the crap out of the thing that makes it move.
countrywoman
  • worcestershire
    • skoda yeti
Re: cylinder head
« Reply #5 on: 04 December 2022, 11:53:42 »
No bodging, the 2 OG heads going back on so it worked out okay. Just need to get the 2 split valve guides renewed.
Migv6 le Frog Fan
  • Online Online
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: cylinder head
« Reply #6 on: 04 December 2022, 12:45:52 »
Im 99% sure engines in plod cars were big standard.
countrywoman
  • worcestershire
    • skoda yeti
Re: cylinder head
« Reply #7 on: 04 December 2022, 14:31:08 »
Apart from the chipped ECU apparently.
Migv6 le Frog Fan
  • Online Online
Re: cylinder head
« Reply #8 on: 04 December 2022, 16:19:39 »
That should have said big, not big.  :-[ ;D
Cant remember chipped ECU,s being a thing, but my memory is piss poor.
Re: cylinder head
« Reply #9 on: 04 December 2022, 16:56:47 »
The 3.0 could be chipped, but not likely to have been as a matter of routine. Some forces did for certain applications, but you have more chance of finding a rust free ega with ten miles on it for a fiver.
Re: cylinder head
« Reply #10 on: 04 December 2022, 16:57:52 »
Waste of time having that one refurbished then.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: cylinder head
« Reply #11 on: 04 December 2022, 19:33:29 »
  Some 3.0L were "modified" or chipped as the you'ff say, I had a chip from an ex-diplomatic protection car, slightly better fueling, some NIPS cars had larger throttle bodies and a modified map. I think the chip I had is still around Hoof'land. But l haven't asked if the person still has it.
Hoof'land storeman.
countrywoman
  • worcestershire
    • skoda yeti
Re: cylinder head
« Reply #12 on: 04 December 2022, 22:36:40 »
There's a label on the ECU saying its been overhauled so might be chipped.
biggriffin
Re: cylinder head
« Reply #13 on: 05 December 2022, 19:58:48 »
 Common sticker, on factory refurbished units.
Hoof'land storeman.
Re: cylinder head
« Reply #14 on: 05 December 2022, 20:40:10 »
It’s probably from a 2.5 ;D
