Author Topic: Problem with low rpm  (Read 4755 times)
jimjimanta
  • hellas
    • opel omega b , opel manta
« on: 03 December 2022, 21:53:20 »
I have a opel omega 2000cc eith x20xev , 1998 model .
when the engine is at low rpm the rpm goes up and down until to turn off.
then, it doesn't start, only if I put full throttle .
I think so is not problem with the vacuum.
Re: Problem with low rpm
« Reply #1 on: 04 December 2022, 00:22:11 »
You need to clean the idle control valve and throttle body along with the breathers. There is a guide for the 2.2. 2.. Is basically the same.
jimjimanta
  • hellas
« Reply #2 on: 05 December 2022, 22:01:00 »
Thank you for your response.
I can't find the driver.
please , can you  upload the guide ?
« Reply #3 on: 05 December 2022, 23:04:13 »
Should be in the maintenance guides :-\
jimjimanta
  • hellas
« Reply #4 on: 11 December 2022, 10:01:26 »
with a little luck, I succeeded and found the fault, after 10 days of searching.
I mention it to help a friend in the future.
I think it is a difficult damage.
the fuel pressure regulator was at fault!!!
gasoline was poured into the vacuum, with the result that the engine has these symptoms, which refer to another damage.
