Tube for vacuuming oil
Started by TheBoy, 08 December 2022, 09:21:40
Quote from: ronnyd on 08 December 2022, 15:00:51....
Wot, no digital one?  :o ;)
Yes ... but at work.  ;) Infact I've collected a few of them .... must bring one home some time  :y
The current stuff I use thats too flexible is 6.5mm, on my DIGITAL ones ;D
Pela replacement tube is silly money, so looking at semi rigid nylon?  Temps look good enough (up to 120C), not sure if it will collapse, but for sake of a couple of quid, gotta be worth a punt, though its from ching chong land, so will land next year.
YZ250
Quote from: Andy B on 08 December 2022, 14:25:07
for those that remember how to read a proper Very-near  ;D
The batteries never run out on the manual verniers.  ;) :y
Andy is very close to my age so when we did our apprenticeships we had to use both imperial and metric measuring tools, calibrating them against slip gauges, but because we're old, the digital metric type came along quite a bit later. In saying that, I do have a mitutoyo digital vernier ...... but the battery has probably run out.    ;D
Quote from: TheBoy on 08 December 2022, 15:27:29
I'll send you some  ;) You've not recently moved have you?
Quote from: YZ250 on 08 December 2022, 15:29:37
My problem was actually reading an ordinary very-near after years of using a digital .... it's not that I'd forgotten, I just
couldn't see the blasted thing. Where are my reading glasses!  ::)
Quote from: Andy B on 08 December 2022, 15:29:46
Still here in deepest Brakkers :y
Quote from: TheBoy on 08 December 2022, 15:33:42
I'll dig a suitable envelope out  :y
I went through 3 sets of calipers to measure mine before I found a working set.  Must buy some batteries.
YZ250
Pela replacement tube is silly money, so looking at semi rigid nylon?  Temps look good enough (up to 120C), ...........
Mine is semi-rigid plastic of some sort, on a Pela 6000. I'll take a photo of it, with a vernier reading if I have a battery for it. My original measurement was a guesstimate using a steel rule.  :-\
If you Google the Pela 6000, the tube changes size via a rubber adapter.  :y
Quote from: YZ250 on 08 December 2022, 15:39:46
Yeah, looked at the Pela one earlier.  Reports on forums show its a bit delicate in some cars, but spare tubes are available. Sadly, although the headline price for the replacement tube is £15, but the time its been taxed, customs and posted, its £50 :o.
I think the Pela one is a steel tight coil thats plastic coated? Or certainly the one I looked at was (might have been the 650 model)
Quote from: YZ250 on 08 December 2022, 15:29:37...
but because we're old, the digital metric type came along quite a bit later.  ....
indeed .... some what later. We went to UMIST from school (late 70s  ??? ???) & they showed us some digital micrometres. But as you say, it was years later before they became an affordable thing for the shop floor
Quote from: TheBoy on 08 December 2022, 15:54:27...
I think the Pela one is a steel tight coil thats plastic coated?  ...
that's what mine is
YZ250
Apologies, completely ignore my previous comments and listen to Andy.  :-[  It is indeed like net curtain hanger. Plastic coated spring type tubing measuring O/D 5.66mm on my digital vernearial caliper.
My apologies for misleading you.  :-[
Quote from: YZ250 on 08 December 2022, 15:59:02
Can we just rip the pi55 from you now?
;D
YZ250
Quote from: TheBoy on 08 December 2022, 16:21:00
;D
;D ;D   Yep, I'll give you that one.
A calibrated eye to within 0.5mm but didn't see a ruddy great spring running up the inside.  ;D
