Pages: 1 2 [3]  All   Go Down
Author Topic: Erratic 2.2  (Read 22108 times)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Erratic 2.2
« Reply #30 on: 24 January 2023, 16:07:43 »
Now it's time to measure the fuel pressure so you're not guessing. Changing the fuel filter only ever gives you the nice warm feeling of spending some money. A faulty, or failing, pump is more likely. The relay could also be part of the problem
Re: Erratic 2.2
« Reply #31 on: 24 January 2023, 16:44:57 »
Not to mention the fuel pressure regulator.
  • Chatham, Kent
Re: Erratic 2.2
« Reply #32 on: 24 January 2023, 17:12:44 »
That's another favourite for the I don't know what it's for, or how it does it so it must be faulty school of diagnosis.
Re: Erratic 2.2
« Reply #33 on: 24 January 2023, 17:23:44 »
Well, it's job is to regulate fuel pressure. The best pump in the world won't hold pressure against an open pipe ::)
But whilst we're remotely playing at fixing things...  ;)
ChrisPee
  • Kent
    • Omega Select estate
Re: Erratic 2.2
« Reply #34 on: 25 January 2023, 10:26:08 »
I have a new relay, pump and filter. As far as I know this car hasn't been serviced for at least 5 years - hence the fuel, air, oil filter, oil and plug pre-purchase anyway.
ChrisPee
  • Kent
Re: Erratic 2.2
« Reply #35 on: 21 February 2023, 18:32:51 »
Update, I have had a diagnostic on the car Monday and there were several fault codes - misfire cylinder 1 misfire cylinder 3, alarm, etc etc. I had already replaced plugs, rocker cover gasket, coil pack, fuel filter, fuel pump, cleaned crank breather pipe and throttle body. All fault cleared (and EM light and ABS light. Car then ran great. Started car today (instantly) then began running rough again - fault codes remaining are;
PO170-2 Lean Exhaust Not Present
P1555-0 Throttle Position Sensor (TPS) - load signal not plausible with engine load.
Can someone tell me where the TPS is please?
Re: Erratic 2.2
« Reply #36 on: 21 February 2023, 19:22:07 »
Built into the throttle body ;)
Before you order a new one for the price of another Omega, you have removed it and cleaned it thoroughly as per the guide whist doing all the other work?
ChrisPee
  • Kent
Re: Erratic 2.2
« Reply #37 on: 21 February 2023, 19:37:46 »
Yes Doc, and cleared the tiny 1.5mm hole. It was very gummed and black. Where is the TPS on an Omega, because as of now I'm baffled.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Erratic 2.2
« Reply #38 on: 21 February 2023, 19:48:43 »
------ - - - - -. Where is the TPS on an Omega, because as of now I'm baffled.
Throttle Position Sensor = TPS
Re: Erratic 2.2
« Reply #39 on: 21 February 2023, 19:49:10 »
It's built into the throttle body along with the motor that drives the throttle plate.  ;)
ChrisPee
  • Kent
Re: Erratic 2.2
« Reply #40 on: 22 February 2023, 10:38:00 »
Thanks Doc.
Pages: 1 2 [3]  All   Go Up
